bigsnully8 Oct 2010 20:35Hello everyone,
since I am new to this forum, I’ll just ask right away...
We plan to build a 1 1/2-story house with approximately 130 sqm (1400 sq ft) of living space and a building footprint of 8 x 12 m (26 x 39 ft).
How can you estimate the approximate total cost (excluding land costs) before buying the plot?
Best regards, bigsnully 🙂
Bauexperte9 Oct 2010 11:02Hello,
This sequence almost always indicates the wrong approach. It doesn’t make sense to fixate on a specific desired house and then look for a matching plot; quite often, that exact piece of land simply does not exist.
For a single-family house of this size, depending on the level of finishes, you should expect to start at around EUR 160,000 (USD equivalent) for a slab-on-grade foundation (simple design); a basement adds roughly another EUR 35,000 (USD equivalent). The range above can increase significantly, of course. Additional construction-related costs typically add another EUR 30,000 (USD equivalent).
bigsnully schrieb:
Since I am new to this forum, I’ll just ask… we plan to build a one-and-a-half-story house with about 130 m² (1,400 sq ft) of living space and a building footprint of 8 x 12 m (26 x 39 ft). How can you find out the approximate total cost in the end (excluding the land cost) before buying the plot?
bigsnully9 Oct 2010 14:38Bauexperte schrieb:
This sequence almost always indicates the wrong approach. It doesn’t make sense to fixate on a specific desired house and then look for a matching plot of land; very often, that exact piece of land simply doesn’t exist 😉
For a single-family house of this size, depending on the level of finishes, you should expect a starting price of around EUR 160,000 for the slab foundation (simple architecture); adding a basement will cost approximately another EUR 35,000 – the upper range is, of course, open-ended. Additional construction-related costs come to about EUR 30,000.
Kind regardsHi, we have already found the suitable plot, which is fully serviced and costs about EUR 53,000.
Bauexperte9 Oct 2010 17:09Hello,
Good for you...
...except for the slight chance that "fully serviced" means the utility connections (usually) are located in the street and not actually on the preferred plot. In that case, the additional building-related costs mentioned will still apply 🙂
Kind regards
bigsnully schrieb:
Hi, we have already found a suitable plot, fully serviced, costing about 53,000 Euro....
Good for you...
Kind regards
