ᐅ Corner garage on the building boundary?
Created on: 15 Dec 2011 09:53
Bauexperte
Bauexperte
15 Dec 2011 09:53
Girasol schrieb:
A garage is allowed to be built on the property boundary, but we have to maintain a 3 m (10 feet) distance behind the house. If we want to extend the garage sideways behind the house for bicycles and such, can the extension also be on the boundary? I hope you understand what I mean—like a kind of garage around the corner?
Why not plan a 3 x 9 m (10 x 30 feet) garage with an extension from the start? That way, this question wouldn’t even arise. Otherwise, you should consult the local building planning authority responsible for your area to find out if your idea is permitted. It is difficult to impossible to answer this from a distance, since I have no information about the property or the relevant regulatory requirements.
Kind regards
haeuslemaster
15 Dec 2011 10:57
I can imagine that this is a matter of cost. I have the same problem. But my neighbor didn’t like my idea very much..
Girasol
15 Dec 2011 12:45
The problem is that our plot is not deep enough to build the narrow side of the house parallel to the narrow side of the plot and then plan such a long garage, because there would hardly be any space left to design an entrance there.
Meecrob
15 Dec 2011 14:42
Please upload a floor plan so that it’s easier to visualize.
Girasol
15 Dec 2011 14:47
Unfortunately, I don’t have a picture of this yet, as we are still at the beginning of the planning stage. Whether we buy more than 400 square meters depends on the option for a corner garage. The plot is 21 meters wide and 19 meters deep (69 feet by 62 feet). We are planning the driveway and garage on the far right, situated at the rear right boundary. However, since we want to build without a basement, we would prefer a large garage. One option would be an 8-meter long garage (26 feet), leaving space at the back (with 5 meters overlapping the house, which is 9 meters deep (30 feet)). Alternatively, the garage could be only 5 to 6 meters long (16 to 20 feet), with an extension around the corner at the back of the house.
If this is too complicated to understand here, I’ll probably have to call somewhere to get clear advice.
Thanks anyway.
Bauexperte
15 Dec 2011 17:47
Girasol schrieb:
The plot is 21 m (69 feet) wide and 19 m (62 feet) deep. We plan to place the driveway with garage at the far right on the rear right boundary.
What you plan and what you are allowed to do can be two very different things. Does the zoning plan assign a building zone for the garage on the plot, or are you definitely allowed to exceed your building zone by about +/- 5.00 m (16 feet)?
Girasol schrieb:
But since we want to build without a basement, we would like a large garage. One option would be 8 meters long and space at the back (then 5 meters overlap with the house with 9 m depth of the house) or the garage only 5-6 meters long and then an extension around the corner behind the house.
An 8.00 m (26 feet) depth is feasible cost-wise if you do not exceed 3.00 m (10 feet) in width. On the other hand, if the house depth is 9.00 m (30 feet) (usually there is an obligatory 5.00 m (16 feet) parking space in front of the garage), you would have space for the longer garage; if the zoning plan does not specify a strict building zone for the garage and therefore the state building code applies, you are even allowed to extend the building structure by 3.00 m (10 feet) with the garage. BUT only with the garage; boundary construction with living space is only permitted for semi-detached houses or in rare exceptional cases.
Girasol schrieb:
If that is too complicated to understand here, I guess I will better call someone who can explain it to me. Thanks anyway.
It is always better to ask someone who “knows about this” – responding remotely (I have already mentioned this) is almost impossible without knowing the specific circumstances.
Most building authorities have one day per week open for public inquiries; here in the Rhineland usually on Thursdays. Bring your documents there and you will definitely get help.
Kind regards
