We are currently building a new energy-efficient house and are considering whether to have a core drill hole installed for kitchen exhaust ventilation. Our chosen range hood can operate either as exhaust or recirculation. The project manager recommended using the hood in recirculation mode with activated carbon filters. However, the kitchen installer advises exhaust mode, as only this option supposedly eliminates odors and similar issues effectively.
We are now conflicted and thinking about having the core drill hole made but initially not using it, operating the hood in recirculation mode instead. The core drill hole would be fitted with an external grille cover and internally closed off with a cap. If needed later, we could connect the hood with a duct and have the setup ready for that.
From your point of view, is this a sensible approach, or am I missing something? What would you recommend? Should we have the core drill hole made or rather not?
Thanks in advance and best regards
MachsSelbst19 Apr 2026 14:04If you want it that precise, it's not enough to just say a duct box, for example this one or that one. If you want it that exact, you need to know the duct box you want to install. Then you check the specification sheet and see whether it fits. I would allow for more tolerance; accuracy in construction is a tricky matter...
