ᐅ Core drilling for kitchen exhaust vent?
Created on: 16 Mar 2026 22:59
Haus2626
We are currently building a new energy-efficient house and are considering whether to have a core drill hole installed for kitchen exhaust ventilation. Our chosen range hood can operate either as exhaust or recirculation. The project manager recommended using the hood in recirculation mode with activated carbon filters. However, the kitchen installer advises exhaust mode, as only this option supposedly eliminates odors and similar issues effectively.
We are now conflicted and thinking about having the core drill hole made but initially not using it, operating the hood in recirculation mode instead. The core drill hole would be fitted with an external grille cover and internally closed off with a cap. If needed later, we could connect the hood with a duct and have the setup ready for that.
From your point of view, is this a sensible approach, or am I missing something? What would you recommend? Should we have the core drill hole made or rather not?
Thanks in advance and best regards
Haus2626
17 Mar 2026 14:13
Why did you decide against an exhaust vent in the kitchen? Was it due to cost, or did you want to avoid penetrating the building envelope for efficiency reasons?
Häuschenbauer4
17 Mar 2026 14:40
As you mentioned, due to the core drilling through the building envelope. However, this does not cause any disadvantage if appropriate wall boxes are used. And based on discussions with other homeowners, the decision was made according to gut feeling.
I believe that neither solution is wrong, as long as it is carried out properly.
Haus2626
17 Mar 2026 16:34
We would have the construction company handle this. Besides the core drilling, what else would the construction company need to ensure? Would installing a wall box be sufficient so that the kitchen installer can take care of the "rest" and connect the ventilation duct?
kbt09
17 Mar 2026 17:49
@haus2626 .. the connection for the range hood should preferably be made with a duct rather than a flexible hose.
The kitchen fitter usually has plans for this and can also recommend a good wall duct cover. Naber and Weibel are well-known manufacturers for this. The diameter should definitely be 150 mm (6 inches).
MachsSelbst
17 Mar 2026 22:09
A wall vent box from Rotheigner available at Hornbach should also work, and in an emergency, a hood from Siemens or Neff is acceptable too.
To bring in the perspective of the average person who can’t just spend 3,500-4,000 EUR (3,500-4,000 USD) on the wall vent box and hood alone... many people buy their entire kitchen appliances for that amount.
Then it’s not 1,000 "bucks" but only about 150, plus the core drilling. However, you don’t have to keep replacing the carbon filters constantly, since they only last 2-3 years if the kitchen is mainly a design object rather than a practical cooking space or if you just reheat food occasionally.
Anyone who really cooks daily and properly will wear out even the best carbon filter in 3-6 months, because not even Gaggenau and similar brands can work miracles in that regard.
Ventilating for 10 minutes might sound great... but the smell and greasy steam will remain in the air at first...
Of course, everyone can do as they wish, but many arguments here are simply nonsense... a vented hood doesn’t have to be expensive, especially if you have to choose a recirculating model costing 4,000 EUR (4,000 USD) for it to work somewhat properly.
nordanney
17 Mar 2026 22:36
MachsSelbst schrieb:
Anyone who really cooks every day and properly will wear out even the best carbon filter within 3-6 months, because not even Gaggenau and similar brands can work magic.
No. The hood tells you that. At least for Berbel, with intensive daily use, the larger filters last 2-3 years.
To bring back the perspective of the average person, who can’t just spend 3,500–4,000 EUR on the duct cover and hood alone
Did you read the thread? A cheap recirculating hood doesn’t help much. Cheap and ducted – then you don’t need an expensive hood. Expensive hood and ducted exhaust are a luxury – want, not need.
Of course, everyone can do as they please, but many arguments here are simply nonsense... a ducted hood doesn’t have to be expensive,
Nobody said that. Please read carefully.
if you have to get a recirculating hood, it has to be a 4,000 EUR model to work somewhat properly.
Again, nobody said that. No need to exaggerate just because no one jumped on your bandwagon.
