I am facing the following issue: In my new kitchen, I had a beautiful ceramic countertop installed (cost: 2000 EUR). I wanted a cooktop with an integrated downdraft extractor. On the recommendation of the kitchen installer, I had a flush-mounted cooktop from manufacturer X installed, which after six months turned out to be of poor quality. I would now like to switch to a cooktop from Siemens or a similar brand.
The problem is that cooktops from other manufacturers have different dimensions, and the cutout in the countertop is too large. Replacing the entire countertop would be absolutely crazy in terms of cost and waste of resources.
How is this type of problem usually handled? Unfortunately, it seems that cooktop installation dimensions are not standardized. It can't be that every time you change a cooktop, you need a new countertop, can it? Do you have any experience with this and maybe some tips that could help me make a decision?
Thanks in advance!!
Thanks in advance!!
Is it oversized in just one dimension or in both? If only in one, I could imagine turning this into an advantage by using some kind of insert where you can place cooking utensils or pot lids (on the right or left side). Or a power strip (of course with a cover) at the front or back. My wife always complains that the power outlets on the wall (our cooktop is in front of the window) are too far away from the cooktop—she always needs the immersion blender for her soups. So, I will have to cut a hole in the countertop and install a power strip soon.
Tolentino schrieb:
Is it too large in only one dimension or in both?It is about 1cm (0.4 inches) too wide.Ok, this is obviously an annoying gap. Too big to fix with just silicone, but too small to start with anything else.
I’m not sure if it’s possible, but I could imagine that using stone powder and resin or something similar might make it look very close to the ceramic.
Something like artificial stone, available locally. Maybe you’ll find something there, sorry, I can’t think of anything else.
