ᐅ Mechanical ventilation with heat recovery – is the design suitable?
Created on: 12 Jun 2014 09:09
Hampek
I have now received the finalized design for the central mechanical ventilation system with heat recovery from the specialist planner. It would be great if you could take a look and share your feedback. My main concern is the placement of the supply and exhaust air points. Unfortunately, we need to move quickly as the builder is applying pressure... 🙁
Magenta indicates supply air, and "orange/yellow" indicates exhaust air. Many thanks.
Robert
Here are the images:
Grundrissplan eines Gebäudes mit farbigen Markierungen und Abmessungen
Grundrissplan eines Hauses mit farbigen Markierungen und Notizen
Detaillierter Hausgrundriss mit Zimmeraufteilung, Wänden und Markierungen
Grundrissplan eines Hauses mit Eingangsbereich, Zimmern und Maßen
€uro
12 Jun 2014 18:08
wadenkneifer schrieb:
[....Please tell me that your negative example is fabricated....
No, why would I bother?
Only "Blau" is from me.
As an expert and planner, I come across the most peculiar things ;-)
Hampek
13 Jun 2014 10:58
First, thank you for the discussion.
In another forum, I came across a study that states it is not absolutely necessary to follow the supply air and exhaust air principle strictly in a single-family house. Therefore, air circulation around doors is quite acceptable.
For this reason, I would find it very practical to place the supply air vents on the first floor as well, since I don’t see many other options. After all, these vents shouldn’t be located above the desk or bed, and the rooms aren’t very large. The only exhaust vent I would position above the toilet in the bathroom.
Any concerns from your side? Unfortunately, I’m under pressure and have to make a final decision by around 3:00 PM today.
Thanks and regards,
Robert
Wastl
13 Jun 2014 11:22
A supply air vent above a bed or desk doesn’t cause any issues. In our case, there is a supply air vent in the ceiling above the bed. With a room height of 2.50 meters (8 feet 2 inches), you don’t feel anything at all. I can feel a slight air movement only within about 10 cm (4 inches) around the vent; beyond that, the airflows are so slow that they are not noticeable. Since the ducts run in the ceiling cavity, you should have complete freedom to position the supply and exhaust air vents as you wish.
Hampek
13 Jun 2014 11:25
According to Helios' planning manual, the valves should not be positioned directly above a bed. What type of valves have you installed, please?
Wastl
13 Jun 2014 14:39
Round with a plate in the middle – no idea what they are called.
