ᐅ Mechanical ventilation duct – screws protruding inside the duct!!!
Created on: 28 Nov 2014 09:21
el_curioso
I had a house built through a developer. A mechanical ventilation system with heat recovery was integrated into the insulation layer. The ventilation ducts are made of galvanized steel in rectangular duct design.
After the house was completed, I wanted to vacuum the ducts because a lot of dust had accumulated. I found that at every joint between two ducts, several screws protrude into the ventilation duct. This makes it almost impossible to insert the vacuum hose, and I almost couldn’t pull it back out.
According to the company that installed the system, fastening rectangular ducts/ventilation pipes with self-drilling screws is standard practice and allowed.
In my opinion, this makes it impossible to properly clean the ducts, which I consider a serious defect.
Are there any regulations, standards, or guidelines on this?
Has anyone experienced a similar problem?
Thank you very much for your help.
Thomas.
el_curioso
4 Dec 2014 13:11
I will try to take a photo this evening and then upload it here.
Obviously, using a vacuum cleaner is not the most professional way to clean, but it is the simplest method for beginners.
