ᐅ Control of Multiple Roller Shutters
Created on: 16 Jun 2019 10:34
lesmue79
lesmue79
16 Jun 2019 10:34
Hello, how can I control multiple roller shutters in one room individually but with as few switches as possible, without having to equip the entire house with a smart home system? My home builder sells Homematic products. But apart from the 3 roller shutters in the living and dining area, which I would like to control centrally yet individually and with as few switches as possible, I don’t really need a smart home system right now.
So, simply put, a switch with 3 buttons/toggles: one for up, one for down, and one to cycle through the roller shutters? This switch would be installed in a central location, with all the roller shutters in that room assigned to it?
guckuck2
16 Jun 2019 10:57
That can also be handled with conventional electrical work. Ask the electrician.
lesmue79
16 Jun 2019 11:03
Okay, thanks, then I’ll ask again. At first, they gave me the impression that they were really trying to push some kind of smart home system for sure.
Mycraft16 Jun 2019 11:56
Use motors with remote control. This way, you can group them however you like without much effort or wiring, which is also easy for beginners.
boxandroof
16 Jun 2019 13:51
Mycraft schrieb:
Use motors with remote control. This way, you can group them however you want. No major effort or wiring required, so it’s easy even for non-professionals.
Exactly, that makes you much more flexible.
For us, it wasn’t any more expensive than if the electrician had installed his outdated timers.
nitrox1337
26 Jun 2019 09:14
Basically, everything is possible. With conventional electrical systems, you can achieve almost everything that you can with smart home technology or PLCs (programmable logic controllers). The question, of course, is whether the cost-benefit ratio is worth it, or if it’s better to just go with the smart option. There are third-generation Teepao switches available that connect to Wi-Fi, work with Alexa and the Smartlife app, are autonomous, and you only need to buy the switches themselves. They cost about 25€ and work perfectly. Compared to regular switches, they’re not more expensive.
Nitrox
