ᐅ Control the climate using underfloor heating or through the ventilation system?
Created on: 25 Oct 2015 09:42
merlin83
We are considering installing an air conditioning system to cool the house during the hot summer temperatures (which now usually last for a solid 2 to 3 weeks per year).
Has anyone installed an air conditioning system and can share their experience? Do you cool via the underfloor heating system or through the ventilation system?
merlin83
merlin83
This summer, it was quite warm inside my house despite having external shading on the windows, but it was still manageable for me. However, I can imagine that in 20 years, when I am older, it might be different. Otherwise, split units, like those used in split air-source heat pumps, consist of a heat exchanger with a fan indoors, and a box containing the compressor and a fan outdoors, connected by cables and pipes carrying the heat transfer fluid.
Sebastian7927 Oct 2015 13:04Don’t forget the condensate drain connection – this is unfortunately the biggest challenge when retrofitting.
Sebastian7927 Oct 2015 13:09You can do that – if you don't care about airtightness and want to create a nice thermal bridge.
Unfortunately, this is often how retrofitting is done.
With a small trap, it becomes airtight, and in winter you can put a plug on it. Airtight and insulated with plastic/air is reasonably effective; you will have a significant thermal bridge anyway where it passes through, especially when retrofitting. In my opinion, this might be better than spending several thousand euros on installing pipes inside the house (which is a hassle once the house is finished). Thanks for the information about this solution.
Sebastian7927 Oct 2015 13:21I don’t have a thermal bridge because it is constructed from the cold attic space.
Where do you want to install the siphon? Outside on the wall? And no one will put a plug on it during winter, probably.
But of course, it definitely won’t be a major issue – it just needs to be considered.
