ᐅ Construction supervision through a homeowners’ protection association, private builders’ organization, technical inspection agency (such as TÜV or DEKRA), independent expert, or another option...?
Created on: 2 Dec 2015 16:04
Bauexperte
A friendly hello to everyone,
who doesn’t know it... or has at least read or heard somewhere: external construction supervision is supposed to help avoid trouble/problems during the adventure of building a house!
Since this topic often comes up in discussions, I would like to ask you to share your personal experiences with experts or associations on the way to your own home in this thread:
  • Why did you hire external construction supervision?
  • Which expert did you work with?
  • How many inspections (at which stage of the construction process) did you arrange?
  • What did it cost?
  • What are your experiences?
  • Would you make the same decision again?
Homeowners who consciously decided against external supervision:
  • Why did you choose not to use an expert?
  • Would you decide the same way again?
As this thread fills up with contributions (which I hope it will), I will pin it at the top of this section. Then every potential homeowner – before starting their project – can get information on the pros and cons of both options.
Thanks for your support!
Best regards, Bauexperte
Goldi09111
6 May 2016 22:29
I am also wondering about this as we are currently considering working with an architect to go into more detail...
Kaspatoo10 Sep 2016 12:42
We are leaning towards using an external construction supervisor, for example from a home owners’ protection association (8-9 visits, approximately €250 (about $275) each at €85 (about $93) per hour).
We are also considering building with an architect or a construction company. However, it is often the case that construction companies work with the same architects. In such cases, the independence of the parties involved should be questioned.
If you plan to work with an entirely independent architect and handle the tenders and so on through them, I would rather not use an external construction supervisor. In my view, this responsibility then lies with the architect (as Sebastian already mentioned).
In this case, a contract for construction supervision should be signed with the architect, so that they can be held accountable. Nothing should be based on verbal agreements.
Bauexperte
10 Sep 2016 13:54
Kaspatoo schrieb:
If you work with a completely independent architect and then handle the tendering process with them, I would generally avoid using an external construction supervisor. In my view, the architect takes care of that.
I do not understand this logic. Architects never make mistakes...? Regards, Bauexperte
Sebastian79
10 Sep 2016 14:02
And construction supervisors never? Of course, you can take extra precautions, but ultimately, in architect-led construction, it’s wasted money—and it undermines trust in the architect.
Kaspatoo10 Sep 2016 14:05
You need someone to supervise the contractor.
If you hire an independent architect and put the project out to tender, I assume that the architect and the company awarded the contract are not connected. In other words, I assume the architect is independent from the construction company.
For me, bringing in a fourth party does not add much value. The architect already takes on the supervision role. However, in this setup, there is no one to oversee the architect themselves. So what else needs to be supervised? The planning? That’s possible. If desired, you could have another independent expert review the architect’s plans. In my opinion, though, there’s no need for an external party to watch over the architect as they oversee the construction company or to check the same trades that the architect already inspects. Since, as mentioned, I consider the architect to be independent, I do not see this as necessary.
On the other hand, if you work with an architect or a general contractor who is connected to the construction company, then the architect’s independence is questionable, and an external expert is required.
Saruss
10 Sep 2016 14:05
But a construction supervisor may be specialized in this, while an architect, firstly, also handles many other tasks and might not be entirely independent (for example, when working with regular contractors they are familiar with).
Sent from mobile
