ᐅ Construction Supervision in the Dortmund Area: Private Homeowners Association or Technical Inspection Agency
Created on: 3 Jul 2016 20:08
bvlgari
It is undisputed that we want to work with a construction consultant. We have gathered a few offers and now face a tough choice: either a consultant from the regional office of the Association of Private Homeowners or an independent/freelance expert recommended by a friend.
Both would visit the site 7 times and provide 7 reports, but one costs around €1600-1800 and the other a flat fee of €2600.
The more expensive, independent expert is supposed to be very good (according to my friend), but simply spending €800 more upfront for something I can get elsewhere for less... well.
Any advice or recommendations?
M.
O
ONeill
4 Jul 2016 21:14
nightdancer schrieb:
Hmm, are your friends qualified enough to assess whether their own construction supervision was sufficient? Respect for their expertise. The TÜV is the standard for building inspections?! Well then.....
Bauexperte
4 Jul 2016 23:21
7 site visits are simply not enough for qualified construction supervision/monitoring.
Says who...?
Regards, Bauexperte
Bauexperte
4 Jul 2016 23:27
bvlgari schrieb:
The expensive independent expert is supposed to be very good (according to my friend), but just spending 800€ (about $860) more right at the start for something I can get elsewhere for less... well.
In my opinion, you should listen to your friend and hire the independent expert; after all, it’s about more than just money, right?
The TÜV® usually offers 5 inspections; this is generally sufficient because they check the stages during house construction that cannot easily be corrected after handover if a defect is found.
If an independent expert offers 7 inspections, I consider that appropriate; certainly not too few.
Regards, Bauexperte
bvlgari
5 Jul 2016 07:43
The TÜV® usually offers 5 inspections; generally, that is sufficient because they check the stages of construction that cannot easily be corrected after handover if defects are found.
If an independent expert offers 7 inspections, I think that is reasonable; definitely not too few.
Best regards, Bauexperte
Thank you, Bauexperte. It’s probably true that the independent expert is good. But you can’t go wrong with an expert from a Private Homeowners Association regional office either, right? And then it’s 800€ cheaper because they have fixed fees.
Bauexperte
5 Jul 2016 08:29
bvlgari schrieb:
But you can't go wrong with an expert from a Private Homeowners Association regional office, right? And they are 800€ cheaper because they have fixed fees.
You asked for opinions; this is my response.
Basically, the Private Homeowners Association is not a bad choice; I would just also ask for references from this expert.
Regards, Bauexperte
Hausbau Re
9 Jul 2016 22:39
We have Mr. R. from Herne from the Homeowners’ Protection Association, and he conducts 8 inspections including documentation for a flat rate of 2500€ (approx. $2700). We are building in Recklinghausen.
I have removed the expert’s name; you must not post the full name without their consent. If a user contacts you via private message, you can of course provide it.
Regards, Bauexperte
Bauexperte
