ᐅ Construction Phase – What Should Best Be Avoided During This Stage
Created on: 21 Feb 2020 16:53
allstar83
What were things during the construction phase that you would have been better off avoiding in hindsight?
For example, too much supervision, no time off, too many changes, no expert consultation, etc.
Looking forward to your experiences!
Thank you
Vicky Pedia21 Feb 2020 22:54
Source: Often recommended, otherwise found via search engine. Prices vary widely. There are daily flat rates or billing by the hour. The hourly rate is usually between 50 and 80 EUR (approximately 55 to 90 USD) net. This should include travel to the site, phone calls, and other expenses. The inspector should not charge for every minor issue.
Tassimat
21 Feb 2020 23:26
nordbayer schrieb:
How did you measure? Which laser measuring device would you recommend?
What should be avoided? Measuring every last millimeter pedantically.
Millimeters are practically irrelevant in construction.
(In response to the question: Just buy the cheapest one available)
Vicky Pedia21 Feb 2020 23:30
Tassimat schrieb:
What should be avoided? Measuring the last millimeter obsessively.
Millimeter is a foreign word in construction.
He is right! If the mason has found the correct plot, that is already enough.
nordbayer
22 Feb 2020 08:08
Vicky Pedia schrieb:
He is right! If the mason has picked the right plot, that is already enough
When building on the boundary, it is not even that simple
Pinkiponk
22 Feb 2020 08:27
M4rvin schrieb:
We had an (independent) construction supervisor throughout the entire building process and also had the planning reviewed by an expert.
I understand the part about the construction supervisor; it should be an "Independent Expert for Construction Supervision (IHK), publicly appointed and sworn in court."
I have two questions about this: What kind of expert?
Second question: Would you like to have the -->planning reviewed by an expert<--
OR
Should an expert have been the one to -->review the planning<--?
I hope I have made the difference clear.
M4rvin22 Feb 2020 08:38
Pinkiponk schrieb:
I understand the construction supervisor part; it is supposed to be an "Independent Expert for Construction Supervision (IHK), publicly appointed and sworn in by the court."
I have two questions regarding this: What kind of expert?
Second question: Would you like the -->planning by an expert<-- to be reviewed
OR
should an expert have reviewed the -->planning<--?
I hope I made the difference clear.
Okay, let me explain further!
Our planning (such as floor plans, submission plans, etc.) was done by the general contractor. Unfortunately, it was quite “poor,” which might have been noticed by an expert (someone familiar with this).
The major issues that caused us sleepless nights were:
- House built too low
- Controlled mechanical ventilation system doesn’t fit into the house
- Therefore, no gas heating but an air-to-water heat pump instead
- Wooden staircase does not fit inside
