ᐅ Construction of a multifamily house or two semi-detached homes built to KfW40+ energy efficiency standard
Created on: 22 Feb 2020 05:38
superzapp
superzapp
22 Feb 2020 05:38
Dear Community,
The plots have just been purchased, and the floor plans are quite finalized.
Now we are at the very beginning of the rest of the planning for this new build. I still have many questions regarding construction details and building services that have not yet been sufficiently clarified. I would like to present the project as planned so far and explain our ideas. Due to the size of the plots and the development plan, there are unfortunately quite tight limits regarding the size (which affects, for example, the need for a separate technical building, etc.).
The following key data have already been decided:
Two plots (two owners = one is my brother, one is me).
Border construction is mandatory, resulting in two semi-detached houses (one per plot, each with two residential units). The building will be two stories (eaves height limited to a maximum of 4.5 m (15 feet)).
Gable roof with a pitch of 30-45°, maximum height 9 m (29.5 feet) (all maximum heights measured from the top of the finished floor level). No basement. The upper floors will be accessed via external stairs.
Left half: 2 units each approx. 65 m² (700 sq ft), right half: 2 units each approx. 45 m² (480 sq ft) (each upper floor unit is naturally about 4-5 m² (43-54 sq ft) smaller than the ground floor unit).
The ridge runs west to east, meaning the roof surface for photovoltaics is precisely south-facing.
The ground floor faces south with many windows and doors; the upper floor rooms each have a roof window. The attic is insulated but only accessible via an emergency staircase. Balconies on the upper floors are oriented west or east.
Three residential units will be rented, and I will move into the small 45 m² (480 sq ft) ground floor unit.
A separate technical building of about 8 m² (86 sq ft) is detached from the house by about 1.5 m (5 feet) (for heat pump, storage tank, water, and electrical connections). Due to the necessary space requirements for the technical equipment and boundary setbacks, this is hardly feasible in any other way.
Our wishes and technical/building details as far as feasible:
Solid wood construction. The wall and roof build-up has already been roughly calculated by an energy consultant based on our initial design drawings and considered okay for KfW40 Plus standard. Some details for windows and precise thermal bridge calculations are still missing.
Wall construction from interior to exterior (U-value: 0.11 W/m²K)
1.25 cm (0.5 inch) gypsum board Thermal conductivity: 0.25 W/mK
10.00 cm (4 inches) solid wood wall Thermal conductivity: 0.13 W/mK
26.55 cm (10.5 inches) wood fiber insulation Thermal conductivity: 0.039 W/mK
6.00 cm (2.4 inches) wood soft fiber insulation boards Thermal conductivity: 0.040 W/mK (plaster base)
1.20 cm (0.5 inch) exterior plaster Thermal conductivity: 1.00 W/mK
Total thickness: 45.00 cm (17.7 inches)
Roof construction from exterior to interior (U-value: 0.13 W/m²K)
A Inhomogeneous layers: 10% structural wood
1.5 cm (0.6 inch) gypsum board Thermal conductivity: 0.25 W/mK
2.25 cm (0.9 inch) air layer Thermal conductivity: 0.16 W/mK
24.00 cm (9.4 inches) structural wood Thermal conductivity: 0.13 W/mK
8.00 cm (3.1 inches) wood soft fiber insulation boards Thermal conductivity: 0.042 W/mK
B Inhomogeneous layers: 90% insulation between rafters
Total thickness: 35.75 cm (14 inches)
Ground slab from inside to outside (U-value: 0.14 W/m²K)
7.0 cm (2.8 inches) screed Thermal conductivity: 1.40 W/mK
12.00 cm (4.7 inches) impact sound insulation board Thermal conductivity: 0.032 W/mK
24.00 cm (9.4 inches) reinforced concrete with 1% steel Thermal conductivity: 2.30 W/mK
10.00 cm (4 inches) EPS (expanded polystyrene) Thermal conductivity: 0.035 W/mK
Total thickness: 53.00 cm (21 inches)
(The 10 cm EPS is planned to be replaced by foam glass gravel; thickness will be determined once windows are finalized and the building recalculated.)
The wall construction might still be adjusted to achieve thinner walls by using higher-performance insulation materials (e.g., 0.031 mineral wool instead of wood fiber boards with about 0.039). But only if a) summer heat protection remains effective and b) ecological compromises are not too great. Unfortunately, I am not yet very familiar with the advantages and disadvantages of mineral wool compared to wood fiber insulation boards.
The perimeter insulation of the slab is planned with around 40-60 cm (16-24 inches) of layer-compacted foam glass gravel (required insulation thickness will be calculated).
Overall, we want to build as ecologically as possible and achieve high living comfort. Of course, since I plan to live here for the next 30-50 years if all goes well. Our priority is not primarily the construction costs but what makes sense energetically and ecologically. However, there is a maximum budget. I believe economy and ecology can be reconciled at least with a good compromise. We also hope — thanks to the currently quite generous subsidies for KfW40 Plus buildings — not to have to exhaust this budget.
Our further wishes:
  • KfW40 Plus standard
  • Air-to-water heat pump (alternatively ground-source heat pump if it offers significant advantages). There is not enough space for trench or surface collectors.
  • Photovoltaics (approx. 13-14 kW peak capacity possible), possibly split into two systems
  • Li-ion battery storage (approx. 13 kWh, possibly Tesla PowerWall or are there more ecological alternatives?)
(Problem with electricity: What do we do with excess electricity that the heat pump doesn’t consume and that can’t be used as common area electricity? Tenant electricity models seem complicated and difficult?!)
  • Controlled mechanical ventilation with heat recovery
  • Additionally, we would like to have cooling if possible. Various options are being considered, each with different pros and cons:
  • Cooling via the underfloor heating system (done by the heat pump) with low efficiency
  • Cooling via separate ceiling or wall cooling (cost/benefit?)
  • Ceiling heating/cooling as an alternative to underfloor heating
  • Cooling via the ventilation system with downstream cooling coils per dwelling unit (disadvantage: condensate hard or impossible to control?)
  • Air conditioning units
  • Idea: to install a kind of earth collector to feed permanently cool air into the ventilation system, using a bypass when cooling is needed.
So, this is the first batch of information. I look forward to plenty of feedback.
Next week, we will visit the company with which we want to build and have our plans reviewed and adjusted where necessary. Only then can we get initial cost estimates for the building envelope.
haydee
22 Feb 2020 07:36
Can you rent out the apartment cost-effectively?
Is an external technical room possible? It becomes more expensive if the rooms are located in the garage.
Why KfW 40 Plus and not a Passive House from the start?
NABU provides an overview of ecological insulation materials.
Search for NABU insulation materials.
Regarding ETICS (external thermal insulation composite systems), Fraunhofer conducts research with mealworms and has a facility (to my knowledge not yet operational) for recycling. If both work on a large scale, they should not be underestimated.
Solid wood construction and ecology.
There is not enough wood to sustain the construction boom without using other materials. Ask where your wood comes from, not just where it’s ordered.
Otherwise, I like solid wood and would use it again. However, I have doubts about its ecological impact.
Unfortunately, there is no comprehensive list showing the environmental impact of building materials from production to disposal, including transportation (water pollution, CO2, other emissions, global food supply, wildlife, consequences of deforestation, effects of monocultures).
Since you are building KfW40, read up on the systems from Stiebel LWZ604 Air and Tecalor 2.5. These are ventilation heating units with inverter air-to-water heat pumps, making them more efficient than pure air-source heat pumps.
Use photovoltaic electricity for self-consumption and feed the surplus into the grid.
We don’t have cooling in summer and haven’t missed it after 2 summers (Passive House with solid wood, LWZ 604 Air). Shading is important; otherwise, you get roasted.
I could imagine that small apartments warm up faster. More heat is generated inside the apartment than in a large single-family house. More heat is produced overall.
Some are in favor of air conditioning, others are satisfied with heat pump cooling. I guess it depends on how warm you prefer it.
kaho67422 Feb 2020 08:27
Interesting,
I’m much more curious about why you’re planning a huge, very expensive property, but then living in just 45m² (485ft²)? I assume you live alone and so does your brother? How old are you both? Will it be a shared retirement home? Will you show us some sketches? 🙂
superzapp
22 Feb 2020 10:20
No, no… All just wrong assumptions. I already have an (older) house that is now used entirely as an office, while the other floor is rented out.
In the past, I lived there with my family (with a small office), later, when the kids moved out, only with my wife.
But basically living in an office is not healthy in the long run…
Now I still live in an "too large" apartment, but I am moving into the house, into my apartment alone (I am now separated).
One floor is rented out, my brother rents both apartments. He builds “just for fun” with me. He already owns several apartments, plots of land, houses, etc.
I might have different preferences than others here in the forum. Bigger is not always better. I tried living in a tiny house as a test, that was a bit too small. I’m over 50 now, so I don’t want to have too much clutter in my apartment anymore. There is still enough space for children, grandchildren, and other visitors.
In addition, I want to create a nice large outdoor area that I can use in summer. Even though I no longer live at the office, I regularly spend 12 hours there. So why 100m² (1,076 sq ft)? Just for sleeping and showering?
Actually, it’s not about the circumstances of why we are planning a property like this here. It’s about how we can best implement our wishes… 😎
superzapp
22 Feb 2020 10:26
haydee schrieb:
Can you rent out the apartment profitably?
Is an external utility room possible? ...
Fortunately, renting out profitably is not strictly necessary. It should only cover part of the costs. There are also social aspects involved! The planned total budget (excluding the land) should be repaid within 12 to 13 years.
An external utility room is permitted as boundary construction since it does not include a fireplace—meaning no gas, oil, or similar systems.
kbt09
22 Feb 2020 17:42
If your brother is building for fun, I wonder whether there is really a shortage of affordable, nice 2- to 3-room apartments, or if the real issue is a lack of affordable housing for families of 4 to 5 people, which would make it more sensible to convert two semi-detached units of around 65 m² (700 sq ft) each into a single family house? Where I live, that would be a more suitable rental option, unless you need maximum return on investment. It also has the advantage of likely reducing tenant turnover. Just a thought.
