ᐅ Construction Description – How Should This Be Assessed?
Created on: 1 Mar 2011 09:16
O
olas
O
olas
1 Mar 2011 09:16
Hello, this is the description. There is a bidding process, so we want to know the value of the house without the land based on the materials, for example:
Exclusive, two-story low-energy house (energy efficiency class 55) with numerous extras in a wonderful cul-de-sac location.
We offer you a modern, stylish single-family home on a spacious plot. The excellent features and the bright, airy rooms convey a sense of openness and atmosphere. A well-thought-out floor plan allows for sophisticated living on two levels.
The floor plan of the house is as follows:
Ground floor:
Inviting entrance hall with adjacent guest shower bathroom and access to the utility room, large open-plan living and dining area with integrated kitchen and floor-to-ceiling glass doors providing access to the terrace and garden area, plus an additional room.
Upper floor:
Hallway, one bedroom with dressing area, two further bright rooms, comfortable bathroom with tub, shower, two washbasins, and toilet.
Directly adjoining the comfortable living house are a large double carport and three storage rooms (one room with the heating system).
The garden plot and other outdoor areas have not yet been landscaped, allowing you to realize your own ideas and preferences here.
Features
- Wall construction: 1.25cm (0.5 inch) gypsum board, 1.5cm (0.6 inch) OSB board, construction timber (8cm (3 inches)), OSB boards (1.5cm (0.6 inch)), construction timber (24cm (9.5 inches)), wood fiber insulation boards (6cm (2.4 inches)), plaster mortar made of lime, lime-cement and hydraulic lime
- Clay roof tiles
- Plastic-framed windows with triple glazing (U-value: 0.8)
- Electric aluminum blinds in living/dining area and kitchen
- Electric roller shutters
- Plastic-coated window sills
- Floor ceiling: wooden beam structure with screed topping (11cm (4.3 inches) insulation)
- High-quality floor coverings: tiles (porcelain stoneware), linoleum, and vinyl
- Interior doors: plastic-coated wooden doors (white)
- White wooden door frames
- Freestanding wooden staircase (beech, dark stained)
- Gas central heating (condensing technology)
- Underfloor heating throughout the entire ground floor
- Shower bathroom on ground floor, hallway and bathroom on upper floor: heat recovery system
- Fireplace connection (connections for water-based stove available)
- Ventilation system with heat recovery
- Boiler for hot water (750 liters (198 gallons))
- Solar system for heating and hot water
- Electrical system: bus system
The following remaining work has not yet been completed:
- Filling the entrance door
- Landscaping the garden and outdoor areas
Bauexperte
1 Mar 2011 09:26
olas schrieb:
... there is a bidding process
You probably mean for the plot of land? And if so, what size is the prefabricated house going to be – square meters (square feet)?
Kind regards
O
olas
1 Mar 2011 09:35
No, the entire house is being auctioned. These details are noted in the listing, but since we don’t understand much about this, we wanted to know how much money a nearly finished house is worth (land value around 40,000€ is additional).
I hope I have explained myself more clearly now, sorry.
Bauexperte
1 Mar 2011 10:11
olas schrieb:
No, the entire house is being auctioned; this information is noted in the listing. Since we don’t understand much, we wanted to know how much money such an almost finished house is worth (land value of around 40,000€ is extra).
It is difficult to impossible to answer this with so little information; sorry.
A brief explanation for you why a simple answer is not possible:
1. Has the single-family house been partially built, have installment payments been made by the current owner, or is this a developer project where the total purchase price including land is due at the end?
2. Prefabricated houses usually have different resale values compared to traditionally built single-family houses. There are few exceptions, mostly large well-known brands achieve better resale values. So it also depends on which builder has constructed the house so far.
3. Has construction continued on the single-family house, or was there a halt in work—perhaps during the cold season—on the open structure, and can any damage to the building envelope be ruled out?
4. The location/region of the building project also plays a significant role...
If you can provide answers to the above questions, I might be able to give you more reliable information for the Rhineland area. Since parameters vary regionally, in other cases colleagues familiar with the area you are asking about should respond.
You can also—and I consider this the better alternative—seek local professional advice. Buying a nearly finished property can be as much of an unknown as purchasing an older existing building. Before making an offer, it would be sensible to visit the site together with an expert (an appraiser, construction engineer) and get their opinion. After that, you should have a clear understanding of the condition of the property and be able to offer a price appropriate to the state of the single-family house.
O
olas
1 Mar 2011 10:46
Hello, the house is finished except for a few minor details:
- Filling of the front door
- Landscaping and exterior work
Other than that, it is ready. We have already been living here for about half a year. Unfortunately, I cannot say which company built it, as we have no information about that.
The house is located in Lower Saxony, specifically Emstek. Preliminary viewing on 13.03.2011 at 3:00 PM!!!
blurboy
1 Mar 2011 11:19
Hmm, it’s almost to my taste, but hard to say. I’m not really a fan of prefabricated houses, but I would estimate around €250,000 (about $270,000) in that area!
