ᐅ Connection of Insulation Between Basement Wall and Concrete Slab
Created on: 13 Jul 2016 00:35
cumpa
cumpa
13 Jul 2016 00:35
Hello.
Our floor slab is insulated from below with 6cm (2.4 inches) of insulation. The walls of our waterproof concrete structure (also known as a “white tank”) are insulated with 14cm (5.5 inches). The floor slab insulation protrudes slightly on the ground, and the wall insulation was roughly placed on top of it.
However, at some points there is a wide gap / space between the floor slab insulation and the edge of the wall panel, wide enough to fit a hand through. (Thermal bridge)?
Is this normal? The excavation will be backfilled tomorrow.
Attached are photos
Exterior concrete wall with moisture stains; red brick at the foundation, debris on the ground.
Wet metal surface with water droplets above the floor area at a building edge
Close-up of a rusty metal surface over a dirty concrete floor
wpic13 Jul 2016 10:05
No, the perimeter insulation boards should normally be installed and bonded without gaps or thermal bridges. Any gaps must, of course, be sealed. Additionally, the boards need to be positioned upright at the bottom to prevent them from being dislodged during backfilling. Simply using foam insulation will not be sufficient. The gap should ideally be filled precisely with an insulation strip. For filling smaller joints or defects, only PU perimeter filling foams approved for this purpose should be used; however, these should not be applied if there is hydrostatic pressure, which may be the case for you if you have a Wesse bathtub system. The excavation cannot be backfilled as is. Furthermore, a protection membrane with studs must be installed in front of the insulation as a protection against backfill pressure.
cumpa
13 Jul 2016 23:41
Hello Wpic... a system PU assembly foam from Lohr Element was used to seal the joints. We do not have pressurized water, but occasionally accumulating seepage water. After foaming the joints, dimpled membranes were installed....
SV-Bau01
4 Apr 2017 20:27
The waterproofing of the ground slab up to the wall is not necessary, as a white tank construction method has certainly been agreed upon. However, the insulation should be installed down to the bottom and on the ledge of the ground slab to reduce thermal bridges. Then you just have to hope that everything remains sealed. The rest has already been mentioned above.
