ᐅ Connection fees for a previously developed plot of land
Created on: 18 Apr 2016 18:31
Tobi2016
Tobi2016
18 Apr 2016 18:31
Good evening,
If I build an additional house on a property that already has a house on it, am I allowed to tap into the existing electricity, water, sewage, etc. lines, or do I have to run the connections all the way down to the street and have the utility provider install the lines to the new house from there?
Am I permitted to install these lines myself on the property, or do companies like EON and the local council only allow this (for a fee) and usually charge quite a lot for it?
Thanks and best regards
Tobi2016
toxicmolotof
18 Apr 2016 21:35
As is often the case... it depends.
It depends both on what the respective utility company requires and on what you want.
Here’s an example from our experience. A new build next to an existing house on one property.
The water supplier says:
Only one fresh water connection per property with a single meter. No more than that. What you do behind that and how you handle billing is up to you.
The electricity provider says:
Only one main electrical connection per property. It is possible to extend the supply (sub-distribution) to the new house on your side of the build; we will install the new meter. However, if the new house is given its own house number, a second main electrical connection can be provided upon request.
The wastewater company says:
No problem, you can connect directly to the existing sewer line.
Cable TV and telephone:
As you prefer. Either a new main connection installed by us at the usual cost, or a sub-distribution from the existing connection is possible.
So ultimately, you can only find out by contacting the relevant utility companies.
