Hello!
This summer, we plan to build an aluminum pergola with a louvered roof on our garden terrace. Approximately 8 x 4 m (26 x 13 feet), supported by 6 posts. Concrete foundations and rainwater drainage for all posts are already planned. The manufacturer of the pergola would be "C3 Systems." Our house wall consists (from inside to outside) of 20 cm (8 inches) stacked board construction (spruce), wind barrier, 18 cm (7 inches) wood fiber insulation, and a coarse mineral plaster. The pergola is self-supporting on the 6 posts but will also be attached to the wall by three Thermax anchors on the horizontal beam. These will additionally be sealed with a PU adhesive.
The question now is whether the pergola should also be sealed along the top edge (8 m / 26 feet). We don’t mind if a few drops of rainwater drip down between the pergola and the house wall. What matters to me is the longevity of the plaster. Opinions vary widely, from a special wall connection profile with a sealing membrane (cost about €2500, Alwitra "WA 1") to compressed sealing tape with a silicone joint, to no additional sealing at all, allowing water to drain and the plaster to dry quickly (suggestion from the plastering and painting contractor).
Current opinions on the topic include the following:
I have basically ruled out the compressed sealing tape/adhesive option due to high maintenance. However, I am still unsure about the wall connection profile and shading joint options.
I would be very interested in your opinions on this topic!
Thank you very much,
Pascal
- Compressed sealing tape and adhesive/silicone:
- Ages poorly due to weather and different expansion of plaster and aluminum
- Standing water on the plaster
- Difficult to renew (removing old adhesive from plaster…)
- Wall connection profile Alwitra:
- Sealing membrane with pressure bar (probably also fixed with adhesive)
- Very expensive, but will work
- No sealing between wall and pergola:
- Let water drain between pergola and wall so the plaster can dry as quickly as possible
- Concerns about snow and frost—possible damage?
- Concerns about dirt buildup under the pergola aluminum beam (green streaks)
- A gap of 15–20 mm (shading joint) to the wall might solve these problems? Provided that the Thermax anchors are correctly sealed.
Pascal
Hi
When combining timber construction with wood fiber insulation (wood fiberboard with external insulation and finishing system), the issue tends to be more sensitive than pergola manufacturers like to suggest in their attractive brochures. These “just fix a few Thermax boards and apply some silicone” solutions may look neat at first glance but often age rather poorly. Especially along an 8m (26 ft) long joint, the material constantly moves—summer/winter, sun/rain—plus the different expansion rates of aluminum and render. Silicone doesn’t hold up well under those conditions over time.
If the pergola really stands fully self-supporting on the 6 posts and the wall connection is only meant to prevent tipping or lateral movement, I personally wouldn’t install a rigid, full-surface waterproofing membrane with complex sealing. That might sound contradictory at first, but the painter’s approach of “letting it dry out rather than trapping moisture” isn’t that far off. The real problem with perfectly sealed joints is often not external water, but moisture getting trapped behind the construction with no escape route.
Honestly, I find the details around each Thermax fixing point more important. That’s where the actual weak spots occur. If suitable sealing collars or liquid waterproofing are applied correctly there and the drill holes are properly treated, you’ll usually have far fewer issues than with a massive silicone bead running along the entire wall. Using PU adhesive as the only waterproofing layer would be too improvised for wood fiberboard in my opinion, even if some installers seem surprisingly relaxed about it.
A wall connection profile with a drip edge can be useful, but €2500 (USD equivalent) sounds quite ambitious for an 8m (26 ft) connection detail. That price likely includes a fee for peace of mind as well. Have you checked what the actual gap between the pergola and the facade will be? If only 5mm (0.2 inches) of air remains, every movement will become visible later. At 15 to 20mm (0.6 to 0.8 inches) with a neat shadow gap and controlled water runoff, things usually look a lot better.
One more point that many underestimate: with louvered roofs, heavy rainwater doesn’t always behave as politely as in the brochure. Wind-driven rain often pushes water toward the facade. Therefore, I would at least ensure that no permanent water streak runs down the render above. Mineral-based top coats can handle a lot, but constant moisture is not beneficial in the long term either.
