ᐅ Connecting a heat recovery ventilation system to a ground collector heating system?
Created on: 20 Mar 2015 09:18
jx7Hello everyone!
If you are planning a heat pump system with a brine-to-water pump connected to ground collectors, along with a controlled ventilation system with heat recovery, wouldn’t it make sense to connect not only the brine-to-water pump for heating to the ground collectors but also the controlled ventilation system, using it as a ground heat exchanger so that the air is preheated in winter and precooled in summer before entering the ventilation unit? Most likely, the ground collectors would need to be sized somewhat larger to handle this additional task.
The same would probably apply to a gas-driven zeolite adsorption heat pump operated via ground collectors.
Am I understanding this correctly? What are your thoughts?
jx7
jx7
