ᐅ Hiding Scratches on Malm Furniture – What Are the Recommended Methods?
Created on: 10 Jan 2022 18:37
hau10Hello everyone,
Some time ago, I bought furniture from the IKEA Malm series, and unfortunately, several small scratches have already appeared on the surfaces. This is especially noticeable on the light-colored surfaces, which is quite bothersome. Now I am looking for practical and proven methods to effectively conceal these scratches without too much effort or having to completely refinish the furniture.
I am particularly interested in recommendations for materials or specialized repair products that work well on MDF and veneer surfaces. Tips on application techniques, important considerations (e.g., preparation, drying times, long-lasting durability), and common mistakes to avoid would also be very helpful.
Does anyone have experience with the best way to visually remove or conceal scratches on Malm furniture? Which solutions are affordable, effective, and leave the least visible result?
Thanks in advance for your expertise!
Interesting question, as opinions on this vary widely. Many swear by those special furniture repair markers made specifically for IKEA Malm. But honestly, they often only mask scratches superficially and usually don’t last very long.
My advice is actually simple but realistic: If the scratch is deep, the only solution is to sand it down lightly with fine sandpaper and then apply a thin layer of white paint or replacement foil. Sure, it’s more work, but it lasts significantly better than markers or wax crayons that just paint over the surface.
And let’s be honest: Malm surfaces are not exactly high-end wood; they’re lacquered foil and coated MDF – so every “repair” quickly becomes a gamble. If you want something neat and long-lasting, you should consider re-foiling the piece or applying protective film instead.
All of this, however, should be done thoughtfully. Not everyone wants to spend hours on something that will eventually still be noticeable. Some scratches tell a story – the question is how important perfect appearance really is ;-)
hau10 schrieb:
I’m especially interested in recommendations for materials or specific repair products that work well on MDF and foil surfaces.
Keatondra11 Jan 2022 08:43Hello hau10,
I can help you with this because I have repaired Malm furniture several times myself. The surfaces are actually foil laminated on MDF, which makes repairs a bit more challenging since the finish doesn’t have a real wood texture.
For superficial scratches, I usually use repair markers that are specifically made for white furniture. They are relatively inexpensive and easy to apply. Important: Clean the surface thoroughly beforehand (no greasy residue) and after drying, gently wipe off any excess marker to avoid stains.
For deeper scratches,
Finally, a fine clear coat over the repaired spots can help improve durability. However, this method requires some patience and a delicate touch.
If you want to know exactly which products I use, I’m happy to share the names or links.
GALEO4 schrieb:I agree partially. You should be very careful when sanding to avoid damaging the foil too much. Sometimes a special wax stick is enough to improve the appearance and visually conceal small defects.
My advice is actually simple but harsh reality: if the scratch is deep, the only solution is to carefully sand the area with fine sandpaper and then apply a thin coat of white paint or foil replacement.
Hello everyone and hello hau10,
I’d like to offer some support with a bit more technical background, as I have repaired several Malm furniture pieces in our family.
The issue with Malm furniture lies in the material composition: the surface laminates are melamine resin or decorative foils pressed onto MDF boards. This is not solid wood, but a hard plastic coating that is not very thick. Therefore, when the foil is scratched off, noticeable differences in color depth and reflection appear quickly.
To achieve the best possible result when repairing, I recommend the following process:
1. Cleaning and preparation: Clean the surface with a lint-free cloth and a mild cleaning agent. Remove dust and grease, otherwise nothing will stick.
2. Assess the scratch depth: Are they just superficial micro-scratches or deeper gouges? For superficial damage, a fine furniture polish stick or wax stick often suffices. For larger defects, after lightly roughening the edges (fine sandpaper, e.g. grit 600-800), a suitable repair wax should be used.
3. Color matching: Since Malm surfaces are often white or light tones, I always use a shade that exactly matches the foil white. It helps to test small trial areas.
4. Application: Press the repair wax into the scratch with a spatula, then smooth out excess material and let it dry well. It is important not to apply too much, as it will then be noticeable.
5. Sealing: After drying, you can seal with a transparent water-based clear coat. Not too much, just a thin layer for durable protection and less visibility.
Important:
- Do not use aggressive solvents that can attack the foil
- Patience during application; often several thin layers are better than one thick one
- Protect from direct sunlight after treatment to avoid yellowing
Do you have matte or glossy surfaces? This greatly affects the choice of repair material. Matte foils are often more sensitive and show scratches more quickly.
I would appreciate it if you could provide a bit more information about the affected areas and their condition.
Important:
