ᐅ Completely dismantling Billy Regal doors – is this advisable?
Created on: 26 Oct 2023 09:37
Pralis3
Pralis3
26 Oct 2023 09:37
Hello everyone, I am considering completely removing the doors from my IKEA Billy bookshelf to create more flexibility in the room and possibly make the storage space appear more open. My specific question is: Is it advisable to fully take off the doors of a Billy bookshelf? Or are there common issues to keep in mind, such as reduced stability, appearance, durability of the bookshelf, or other technical or practical drawbacks? I would appreciate any experience reports, especially from those who have done this before or who are familiar with the construction of these bookshelves. Thanks in advance for your help!
Surela
26 Oct 2023 13:42
Hello Pralis3,
your question is well thought out and covers the main aspects. I would like to go a bit deeper into the possible consequences of completely removing the doors from the Billy shelf.
First of all, the Billy shelf is basically designed so that the doors are not load-bearing. The stability of the shelf mainly depends on the carcass, meaning the side panels and the bottom, which are firmly screwed or glued together. This means removing the doors does not significantly weaken the construction itself.
However, doors serve several functions that are often underestimated. On one hand, they protect the contents from dust; on the other hand, they contribute to the overall appearance and can create a closed, tidy impression in the room. Removing them will make the shelf look more open, which can be good or less suitable depending on the room size and design.
One point I often see is the hinges. When the doors are completely removed, the hinges and usually their drill holes remain visible on the side panels. Depending on the furniture wood or laminate, this can look unsightly. You might consider cover caps or wood filler, but that would increase the installation effort.
The usage also changes: without doors, dust can settle more easily on the shelf contents, but the shelf appears airier and can be arranged more flexibly, for example with baskets or uniform decoration.
In conclusion: if you don’t mind visible hinge screws and dust is not a big issue, there is no problem removing the doors. If you want to keep the appearance as clean as possible, you should consider whether to retouch the drill holes or use covers.
My question to you: do you want to use the shelf as a fully enclosed unit or rather as a room divider? That can also influence the answer.
joro10
26 Oct 2023 14:03
You can easily remove the doors without any problems. Doing so hardly affects the stability. However, dust will enter more quickly, so you should keep that in mind.
Joe52
27 Oct 2023 08:19
Pralis3 schrieb:
Is it advisable to remove the doors of a Billy shelf completely? Or are there typical issues like loss of stability or appearance?
I did this myself about a year ago and was initially uncertain. Of course, the shelf feels much more open and lighter, which I liked at first. But after a few months, I had to clean more often because the dust on the items became quite visible. I don’t mind the holes left from the hinges; I got used to them. What I also noticed is that when the shelf is fully loaded, it looks less closed off, which is not always practical, especially with so many books.
It’s important to consider beforehand whether you will use the shelf like a regular sideboard or more as open storage. That made the biggest difference for me. Maybe you’re also thinking about using fabric panels or magnetic covers instead of doors—that works quite well too.
All in all: It’s doable and can look nice, but you should weigh the dust buildup and the change in appearance.
Good luck with your decision!
BiDennis
27 Oct 2023 10:27
Hello Pralis3,
I think your approach is good, explaining some basics here in case anyone else is in the same situation. The Billy shelving unit is not originally designed as a fully open shelf, so it comes with doors to protect the contents and help the room look tidier.
Removing the doors visually “lightens” the unit and makes it more flexible if you want to place larger items or decorations that the doors would otherwise block. However, please keep in mind that without doors, dust and dirt can reach the items on the shelves more easily. This might not be ideal if you store books or delicate objects.
In terms of stability, little changes since the doors are not load-bearing elements. However, you should consider the hinge holes: if you want to keep the unit looking neat, you can fill them with putty or use appropriate cover caps to avoid a “work-in-progress” appearance.
Additionally, you might consider adding a back panel behind the unit – there are often versions with or without a back panel, which can further affect dust protection and stability.
So, to summarize: completely removing the doors is a perfectly valid option, but it comes with certain compromises regarding dust protection and appearance.
I hope this helps!
