ᐅ Complete Renovation of a House Built in 1973
Created on: 18 Dec 2016 14:27
DerDirk
DerDirk
18 Dec 2016 14:27
The house purchase is getting closer. However, the property of interest dates back to 1973 and is in worn original condition. Key details:
*150m² (1,615 sq ft) living space (ground floor + upper floor, including 2 rooms, a shower bathroom, and an attic on the upper floor. The attic is planned to be converted into an open space above/in the living room)
*Gable roof
*No basement
*Oil heating (located in the kitchen, not the utility room)
*Rendered facade without insulation
Renovation plan (strip everything out, everything new) with my estimated costs:
*Demolition done personally, possibly two walls by a tradesperson: €1,000
*Roof insulation (above rafters), 3 Velux windows: €25,000
*External thermal insulation composite system (ETICS) with plaster: €20,000
*Oil condensing boiler, solar system, radiators, possibly new pipes: €25,000
*Ventilation system (necessary???): €10,000
*Electrical wiring on ground floor: €10,000
*Windows (1 large sliding door element, 1 floor-to-ceiling door, 5 double casements, 1 floor-to-ceiling double casement, 4 standard, 1 triangular): €20,000
*Interior doors (5 standard, 1 double glass door) and front door: €7,500
*Bathrooms (basic) and guest WC: €15,000
*Living room ceiling – expose beams, drywall and plaster the sloped ceilings: €2,500
*Flooring on ground floor (ceramic tiles in hallway and bathroom, otherwise floorboards/parquet): €15,000
*Upper floor (2 rooms + shower bathroom) materials for DIY work: €10,000
I plan to hire professionals for everything except the upper floor (DIY), possibly handling smaller tasks myself.
1. What is generally missing at first glance?
2. How realistic are my cost estimates?
3. How much should I budget for architectural planning and supervision?
Thank you very much for your help.
Dirk
Bauexperte
19 Dec 2016 00:07
Good evening Dirk,
DerDirk schrieb:
The house purchase is getting closer. The property of desire dates back to 1973 and is in original, used condition. Key data:
*150m² (1600 sq ft) living space (ground floor + upper floor, with 2 rooms, shower bathroom, and attic space on the upper floor. The attic is planned to become an open space above/in the living room)
*Gable roof
*No basement
*Plastered facade without insulation
Have you already inspected the property with a building expert?
Regarding your price estimates – especially since you work in this field, you should know that figures for older buildings are often unreliable. There will always be a “new” issue that will slow down the renovation.
I strongly recommend that you visit the property with an expert and ask for an appraisal. This appraisal will help you understand the full extent of the necessary renovation. Based on this, you or the expert can tender the trades; this way, you will have reliable cost estimates to work with. Additionally, there are funding options available for renovations; you should also check the KfW website, as these subsidies are not to be applied for after other funding.
Best regards, Bauexperte
Altbau1930
9 May 2017 15:06
Is there any update on the costs, or how far along are you with the renovation?
Regards.
