ᐅ Combining Photovoltaic Systems with Air-to-Water Heat Pump Heating and Domestic Hot Water
Created on: 5 Jun 2014 22:15
hululu0
We would like to install photovoltaic panels on the roof of our new build. However, our electrician said that it is not possible to combine photovoltaic with a heat pump because the heat pump uses a different meter than the photovoltaic system.
Can a professional confirm this or suggest a solution that is also cost-effective? :-)
Many thanks,
Jörg
hululu0
7 Jun 2014 13:59
Hello Elina,
I have already calculated that the heat pump for heating can be operated just as cheaply with standard household electricity. Therefore, I can save myself the extra heat pump for hot water.
Bauexperte
8 Jun 2014 09:49
Hello Jörg,
I am not a client; just a mod 😉
hululu0 schrieb:
Do you have any "document" where you have checked the economic viability of the battery storage?
No, I can’t provide that yet, since we have only had the battery storage available for 3 weeks and accordingly have to wait to see what next year’s figures will show.
You can access my website via my signature. If you look under the tab “Our Philosophy” on the left side of the page that appears, you will find the section “Photovoltaics.” There, to present it professionally using values from 2012 regarding electricity costs for selling and buying (in 2014, the rate per kWh is lower), you can download a PDF from our partner. This allows you to at least review the estimated figures for self-consumption in terms of economic viability.
Our cooperation partner for photovoltaics is currently installing a complete system at one of our ongoing construction projects. Since I naturally maintain close contact with our clients, the move-in is planned for November 2014, and I expect that reliable billing data will only be available in 2016.
Best regards, Bauexperte
€uro
8 Jun 2014 11:39
hululu0 schrieb:
.... is a storage or a control that increases self-consumption! ....
Neither storage nor control increase self-consumption, that would be rather silly ;-)
There are air source heat pump manufacturers that make usable photovoltaic inputs immediately and directly available and billable through their control systems!
