ᐅ Combining lightweight concrete blocks and aerated concrete blocks
Created on: 8 Jan 2016 10:56
D.Gerner
D.Gerner8 Jan 2016 10:56
I have a question.
Is it possible to build an exterior wall using lightweight concrete blocks and use aerated concrete blocks to frame the openings for windows and doors, provided that the compressive strength class is the same?
If this is not possible, can anyone recommend a saw suitable for cutting lightweight concrete blocks?
Regards,
D.Gerner
Grym
9 Jan 2016 02:09
Leveling? What do you want to level out?
D.Gerner9 Jan 2016 11:31
When building an exterior wall, eventually an opening for a door or a window is needed. This means that the aerated concrete blocks must be cut. Since aerated concrete blocks are much easier to work with, my question is whether the cut aerated concrete blocks can be used in this way?
Grym
9 Jan 2016 15:43
So you want to build a wall using lightweight concrete blocks and aerated concrete blocks in the same bond? :-O
Polle 1967
9 Jan 2016 17:39
Hello
A tip from us, since we built a house with lightweight concrete blocks about 20 years ago.
The best tool for cutting the blocks is an angle grinder.
This way, you would have solved the problem of working with different materials.
