ᐅ Interior paint for garage made of calcium silicate bricks
Created on: 11 Jun 2019 13:03
Stinson
Stinson
11 Jun 2019 13:03
If there are any painters or professionals here who can offer some advice, that would be great.
It’s about a large detached double garage, built with 24cm (10 inches) non-insulated sand-lime bricks and externally clad with facing bricks, with a pitched roof. This is a new build.
I’m planning to paint it. Plaster seemed too expensive given the size.
Is facade paint suitable for this, for example, a silicone resin-based paint like Pufas, used with the appropriate primer?
The drywall installer said this type of paint would peel off and trap moisture inside. However, it should be possible to find a durable paint suitable for this type of surface.
I would appreciate any tips.
Regards, Stinson
Unfinished attic with wooden floor, railing, roof beams and small windows.
guckuck2
11 Jun 2019 15:18
That’s possible. However, the group supporting breathable walls will always see an issue with that.
Otherwise, you can use silicate paint.
Stinson
11 Jun 2019 17:13
Thanks for the tip! Can a silicate facade paint also be used for this, or should it definitely be one intended for interior use?
Nordlys
11 Jun 2019 22:03
Whitewash lime. 1000 cow barns can't be wrong.
Bookstar
11 Jun 2019 22:25
Doing the plastering yourself is not an option?
guckuck2
11 Jun 2019 22:33
Phew, it’s quite tall, isn’t it?
As a beginner, I’m managing to get it done without transitions.
