ᐅ Coated shower enclosure – 8 weeks old – how to remove limescale
Created on: 2 Sep 2013 17:40
StarAce
Hi,
we decided on a coated glass shower enclosure. Already after 8 weeks, there are lime scale stains on it that are very difficult to remove. According to the instructions, you should use a glass cleaner, but that doesn’t work at all. How can I remove these lime scale stains, and what kind of cleaning cloth should I use? I’ve heard microfiber isn’t good...
Thanks in advance!
Regards,
StarAce
italiano83
29 Sep 2013 09:12
Limescale can only be removed with acid. I am a certified specialist in cleaning and hygiene management, so anything else is nonsense. Sekusept is even from our company and is an alkaline product. You can find acid, for example, in vinegar—hence acetic acid. However, it is very aggressive and can damage the material. Look for acidic sanitary cleaners in a drugstore or supermarket. Usually, amidosulfonic acid is used, which has excellent immediate limescale dissolving properties. However, you should wet the grout lines beforehand because grout consists mainly of lime and can be attacked.
If the limescale is already crusted, it will be difficult to remove.
