ᐅ Closing KALLAX units with magnets – how does it work?
Created on: 11 Jul 2022 08:37
JOKATO
Hello everyone, I am currently exploring an idea on how to secure the KALLAX shelves from IKEA using magnets. My question is: How does the magnetic locking system specifically work for KALLAX cabinets? I am particularly interested in the type and strength of the magnets used, how they are installed on the doors or compartments, and whether there are any specialized installation solutions or accessories recommended for this purpose. It would also be helpful to understand the advantages and disadvantages of this method compared to traditional locking mechanisms like latches or handles. I would appreciate expert advice and experiences to help me get a realistic assessment for my project. Thank you in advance!
kogudra
12 Jul 2022 08:42
Regarding magnetic catches for KALLAX, I would like to add the following:
From my experience and research, it is essential to use appropriate backing plates with the magnet systems—usually small metal sheets or plates—that are installed smoothly and evenly. This significantly improves adhesion compared to direct contact with wood.
Concerning material fatigue: The magnets themselves hardly wear out, but the adhesive can lose its bonding strength over time, especially with frequent opening and closing or temperature fluctuations. Therefore, I recommend mechanical fastening with small screws if possible.
About electromagnetic interference with surrounding devices: Neodymium magnets create a strong but localized magnetic field, which generally does not cause disturbances to electronic devices inside the KALLAX, as long as they are not mounted directly on sensitive parts of the devices.
In conclusion, magnetic catches are an elegant and practical solution when installed carefully.
Timmyse36
12 Jul 2022 10:15
KNUTGI schrieb:
the doors sometimes click quite loudly when they close
Oh yes, I’ve noticed that too, and I have to admit it annoyed me a little at first. But over time, I got used to it – the “click” almost sounds like a small success moment :-)
However, I wonder how this affects children. My little niece initially found it fun to use the doors that way, but sometimes there are situations where the latch should be a bit more secure.
So I’m curious: is there perhaps a combination of a magnetic catch and an additional manual bolt that isn’t too bulky? That might be a good solution for families.
I really appreciate how many different perspectives people share here; it’s incredibly helpful!
SUBEN60
13 Jul 2022 07:48
In addition to the previous explanations, here is a technically precise summary on securing KALLAX cabinet doors with magnets:
1. Magnet type: Neodymium magnets (NdFeB) are best suited due to their high energy product and the resulting strong holding force in a compact size.
2. Installation: Magnets should be recessed where possible to preserve the appearance and avoid scratches. Counterparts made of iron or steel sheets are essential to enhance the holding force.
3. Holding force: The required magnet strength depends on the weight and size of the door. For KALLAX doors, magnets with approximately 3–5 kg (6.6–11 lbs) pull force are a good guideline.
4. Safety: Magnetic closures do not provide child safety, as the doors can be easily opened.
5. Long-term performance: Adhesive may loosen over time; mounting with screws increases durability.
Conclusion: Magnetic closures are an elegant solution with functional advantages and disadvantages. They are ideal for decorative purposes and light daily use. For additional security, supplementary measures should be implemented.
