ᐅ Heat pump split systems instead of a fireplace and air purifier
Created on: 23 Sep 2024 09:17
Lohener
Hello everyone, as mentioned in the question, I want to use split air conditioning units for air purification and quick heating (e.g., when coming in wet from outside).
The otherwise planned underfloor heating systems are not so suitable for this purpose, especially in combination with low flow temperatures.
I am just starting to look into this and would like to know if it makes sense to continue researching.
What I hope to achieve:
Saving the fireplace (easier to plan)
No wood (less dirt on the property)
Cooling option in summer
chand1986
23 Sep 2024 11:35
Lohener schrieb:
I’m really just looking for comfortable warmth when you’re cooled down...
Warm shower or infrared panel.
Alex124
23 Sep 2024 11:36
Lohener schrieb:
Yes, exactly along those lines...
I’m really just looking for a comfortable warmth when you’re chilled...
However, air conditioning is not the solution for that. Consider using a masonry heater with an integrated bench or a sauna instead. Both unfortunately require preheating, but that’s just how it is.
nordanney
23 Sep 2024 12:28
Lohener schrieb:
Exactly like that...
I’m really just looking for a comfortable warmth when you’ve gotten cold...
Then you go under a cozy blanket for 10 minutes – at a normal room temperature of 22°C (72°F) you’ll warm up again before any other heating methods can get you warm.
P.S. There is winter clothing designed to keep you warm outside as well. With proper clothing, no more than your face should be exposed to the cold.
