ᐅ Clearance at the Collar Beam and Principal Purlin Intersection (Gable Roof)
Created on: 14 Aug 2018 09:40
fight84
fight84
14 Aug 2018 09:40
I have a question.
I have a gap, basically an air space, within the insulation.
Is this problematic?
Attached is an explanatory sketch.
Best regards :-)
Schwarzes Hintergrundbild mit bunten handschriftlichen Skizzen und Pfeilen als Diagramm
11ant14 Aug 2018 21:19
If the collar beam level is insulated, I don’t see a reason to add more insulation above that. In other words, I would stop the rafter insulation at this height.
fight84
17 Aug 2018 14:42
Hi,
this was done because the helpers had already done it that way themselves.
Now I am questioning it.
Could the clearance cause any damage?
Knallkörper
17 Aug 2018 14:48
Why should that cause any damage? The free space is outside the thermal envelope.
The fact that the insulation on the sloping ceiling was installed up to above the ridge beam might have the advantage that if the attic is converted later, the work can continue from there.
