ᐅ Urban villa floor plan 185 m² – Requesting feedback!
Created on: 21 May 2019 09:41
ALLuki83
Hello everyone!
I would like to hear your opinions on our long-prepared floor plan, so I’m starting a new thread just before submitting the building permit / planning permission with the current design of our single-family house.
These are the preliminary drafts for the building permit / planning permission, and this is my last chance to review everything and point out any issues.
Basically, everything fits our needs, but before finalizing the detailed planning, there is still some flexibility and the floor plan might be adjusted.
I would be very grateful for your suggestions, ideas, and criticism!
Greetings from Leipzig!
Four views of a two-story house with windows, doors, balcony, and terrace.
Floor plan of a house: living room, kitchen, entrance hall, guest room, bathroom, utility room, storage room, garage
Floor plan of a house: bedroom, two children’s rooms, dressing room, bathroom, corridor, and stairs.
haydee
23 May 2019 18:35
Even if you are buying new, there are standard dimensions to consider.
A table for 10 people doesn’t care whether it’s from Ikea, concrete, or wood.
It does make a difference whether you want delicate 2- and 3-seat sofas or a modern XXL sofa.
Don’t use paint; use a pencil instead.
Squares are enough. Your freezer might fit in the pantry; maybe the door can still open, but you definitely can’t place anything under the stairs.
Where will the guest bed be located?
Putting that aside,
swap the kitchen and living room. Then the fireplace becomes a room divider and is visible from both the sofa and dining area. That would be a shame. Why give up your beautiful picture?
The sofa is placed directly in front of the floor-to-ceiling window. Is that what you want?
Where will the electric piano go?
ALLuki83
23 May 2019 21:09
haydee schrieb:
Swap the kitchen and living room. Then the fireplace becomes the room divider and can be seen from the sofa and dining area. It would be a shame otherwise. Why give up your beautiful picture?
I’m starting to warm up to the idea. It looks great in my head) but then the utility room would have to move to the right side, and we wouldn’t have any space left for the guest room. I’ll try sketching it today.
And the staircase position is also wrong. So it will need a complete redesign.
haydee
23 May 2019 21:57
Why does the building services system need to be replaced
ALLuki83
23 May 2019 22:12
haydee schrieb:
Why does the building technology need to be replaced?
I think it’s better because of the connections and piping. Then, the service shaft could be integrated into the utility room on the right side somehow… and the toilet could be positioned on the right too. It doesn’t work with the drawing. I’ve torn up all the papers.
haydee
24 May 2019 06:37
On the ground floor, the building services, kitchen, and WC do not need to be located together. In our case, they are also spread out. No one has ever said they must be grouped. It becomes more challenging upstairs with drainage if, for example, your bathroom is above the living room. Usually, wet rooms upstairs are positioned above the wet rooms downstairs.
In our case, the bathroom is above the building services, and the utility room drains vertically downwards inside the wall from the cloakroom.
j.bautsch
24 May 2019 08:13
You really need to draw the furniture to scale; toy furniture won’t help you. Regarding the kitchen, I strongly recommend starting to think about it in detail early on (what is absolutely necessary, how much kitchen space you need, whether it should be an L-shape or a large social island, etc.). Once the house is built, it will be too late, so it’s better to do this now. For example, an island requires a certain depth—60 cm (24 inches) is not enough, as things will fall off the back. Always plan for at least 90 cm (35 inches) depth. Common depths are 90, 100, 110, or 120 cm (35, 39, 43, or 47 inches), depending on whether you plan to have only shelves, shallow drawers, or even 60 cm (24 inches) deep cabinets on the back side of the island. Especially if you want seating there, you will need more depth.
