ᐅ Checking the Quality of BILLY Shelving – What to Look For?
Created on: 1 Oct 2015 09:17
Gisin35
Gisin35
1 Oct 2015 09:17
Hello everyone, I am considering buying a BILLY bookshelf from IKEA but have some concerns about the product quality. My question is: What criteria and features should you really pay attention to when assessing the quality of the BILLY bookshelf to ensure you get a durable and sturdy piece of furniture? I am especially interested in tips regarding workmanship details, materials, and assembly. Additionally, it would be great if someone could share their personal experiences – for example, if the shelf has remained stable after long-term use or if issues appeared quickly. Thank you in advance!
Evapau
1 Oct 2015 09:31
Hi, I would pay attention to the connection points – whether the shelves are securely seated and the screws hold firmly. I also always check the surface for scratches or dents. When the shelf is placed, it should stand straight without wobbling.
BauSimon
1 Oct 2015 10:04
Gisin35, regarding the quality of the BILLY bookshelf:
1. Materials: The BILLY bookshelf is usually made from particle board with a melamine surface. These materials are affordable and durable but not waterproof – moisture must not reach the edges.
2. Joints: When assembling, make sure the dowels and metal brackets are properly and securely fitted. A common issue is uneven shelves caused by screws not being fully tightened or misaligned holes.
3. Finish: Check the edges carefully – the plastic edging (ABS edging) should be neatly glued, without gaps or protruding film.
4. Stability test: After assembly, gently wobble the shelf to check if it stands solidly and does not creak. If it does, additional brackets can help improve stability.
Summary: Furniture experts say that good materials combined with careful assembly result in durability. The bookshelf is not designed for heavy industrial use but is quite sturdy for regular residential use.
relupa
1 Oct 2015 10:42
I find this question very important because people often buy too quickly without paying attention to details.
I once had a BILLY shelf that started to wobble at the joints after some time – which was very frustrating.
Evapau schrieb:
...Pay attention to connection points...
That’s definitely true, especially with furniture made of particleboard, where loosening at the screw joints is the most common issue.
I also worry because I want the furniture to look good for a longer time. Question for everyone: Are there any specific care tips to protect the material? I always use a dry, soft cloth, but I don’t want the plastic edges to swell.
RON57
1 Oct 2015 11:08
First of all: Anyone who buys a BILLY shelf gets a solid standard piece of furniture that is quite good for the price.
However, if you want to enjoy it over the long term, you should consider the following points:
- Avoid moisture, as BauSimon already mentioned. Do not place wet cloths or hot pots on it.
- Follow the assembly instructions carefully, especially making sure to tighten the screws firmly.
- After assembly, make sure to attach and secure the back panel properly. It significantly increases stability.
- If the wall is not stable, fix the shelf to the wall using the supplied brackets. This prevents wobbling and improves safety.
Overall, the BILLY shelf is not a high-end piece of furniture, but with some care, it delivers a good result.
keelko
1 Oct 2015 11:29
I like the BILLY shelf because it is so versatile and can be quickly adjusted – a true chameleon among shelves 🙂 Still, I would pay special attention to the edges and the back panel during quality control. Are the edges glued cleanly and is the back panel flat and properly attached? My tip: after assembly, gently tap the corners with your finger; if it sounds hollow, something might not be fixed properly. In that case, it’s better to tighten it again!
And don’t worry, the shelf will easily last several years under normal use – if not longer.
