ᐅ Central mechanical ventilation with heat recovery: supply and exhaust air, door undercut
Created on: 29 Apr 2017 16:22
bluminger
Hello.
We are currently planning the supply and exhaust air outlets for the (concrete) ceilings.
So far, the layout is as follows:
Basement: Exhaust air in all rooms except the storage cellar (currently no supply or exhaust air)
Ground floor: Dining/living/kitchen area (one open space) with both supply and exhaust air, office with supply air, bathroom with exhaust air
Top floor: Bedrooms and children's rooms with supply air, bathroom with exhaust air
A door gap of 5-8mm (0.2–0.3 inches) has been recommended for the room doors to avoid issues with air transfer.
Questions:
Are your ventilation concepts similar? Any experiences?
Does supply air work effectively only through air transfer under the door (in the basement, air would have to pass through the stairwell)?
What are your thoughts on the door gap (5mm (0.2 inches) seems common to me)?
Thanks in advance.
Questions:
Thanks in advance.
Stockheim5 May 2017 10:18Does it make a difference if you have a central controlled ventilation system with heat recovery?
We are getting the Zehnder ComfoAir 350, and I was actually planning to order all the interior doors with sound insulation…
Bieber08155 May 2017 11:28Difference for what? Today, I would also like to have all interior doors as soundproof, but not because of the ventilation.
Stockheim5 May 2017 12:15Is there a difference compared to other ventilation systems, or is it the same for all that air exchange between the individual rooms is required?
Bieber08155 May 2017 13:24Exactly. Typically, living rooms, bedrooms, children’s rooms, studies, and guest rooms receive supply air vents. Fresh air is blown into these rooms. Bathrooms, guest toilets, kitchens, and utility or storage rooms, on the other hand, have exhaust air vents where used air is extracted. Hallways and staircases usually do not have any vents. This means that the fresh air must flow from one room, through the hallway, to another room with an exhaust vent. There are various methods for this airflow transfer, some with and some without sound insulation. It can happen through the door or through the wall (transfer valve).
If airflow transfer is not possible or not desired, each room needs both supply and exhaust air. This involves more effort during construction. Additionally, the air circulation within the room must be managed carefully (to avoid short circuits), which can be more challenging than with airflow transfer. In such cases, a decentralized system might be worth considering, where airflow transfer can also be eliminated.
Stockheim5 May 2017 13:42Could you please explain the options for air transfer WITH sound insulation?
Thanks a lot
Thanks a lot
