ᐅ Central computer system with terminals in the rooms
Created on: 8 Jan 2021 07:37
Chris90
Hello everyone 🙂
I am new to the forum and I hope this is the right place to ask.
I am currently planning a new build. I have now reached the point where I am thinking about the locations for my computers. I work with computers a lot, both privately and professionally.
I am planning an office where I will often work from home. Ideally, I wouldn’t have my computers right next to me, but rather in a separate room. It would also be great if not every child needed their own PC, but this could be managed centrally as well.
I have thought of two options:
1. PCs located in a central room, with signals distributed to other rooms via HDMI or USB cables inside the walls. I’m not sure if this is even possible?
2. PCs in a central room and terminals in the individual rooms. Here I wonder which terminals would be suitable (up to 4 monitors) and whether special software is needed. I am familiar with Citrix professionally, but I don’t know how expensive it could be for private users.
What options do I have or do you use?
Thanks in advance for your advice!
Regards,
Chris
nordanney
8 Jan 2021 11:29
rick2018 schrieb:
Couldn’t you use a soundproof rack? Or put it in the next room?
Even high-performance computers can be made quiet. You don’t really need a gaming PC.
With SSDs and large, slow-spinning fans, it can be quite silent.
Liquid cooling should reduce the noise level to almost zero.
Chris90
8 Jan 2021 11:31
At my workplace, all the PCs are located in one room, and everyone accesses the virtual machines through a terminal. Each user has different monitors with full performance and resolution, but there are no PCs or noise in the office. That’s exactly what I wanted at home as well.
HarvSpec
8 Jan 2021 11:38
Then why not take the solution from the office?
Chris90
8 Jan 2021 11:43
Yes, I will take a look at it later.
I thought there might be people here who already have a similar solution and could offer recommendations.
Apparently, I am alone here with this idea.
I don’t understand why almost everyone finds it strange to put all PCs in one room to avoid noise and have everything neatly centralized...
untergasse438 Jan 2021 11:55
My two servers plus NAS are installed in a rack, which is located far from my desk. Under the desk, there is a PC with a roughly soundproofed case, and on the desk, there are three 27-inch monitors. No problem at all; the mechanical ventilation system in the house is louder. I think making a big effort about this is pointless (though everyone has to decide what makes sense for themselves), or to put it another way: it offers no benefits for home use. Children or others will most likely work on laptops anyway, which are barely or not audible at all.
Besides that: What do you personally use four PCs for in your daily work? That sounds more like a poorly thought-out setup.
Mycraft8 Jan 2021 12:00
Same here. I don’t see any issues with PCs in the home office, even with multiple monitors and a server, NAS, etc., located elsewhere. You can still access everything you need from the sofa using a laptop.
But if you want to do it, then just go ahead.
