We are considering buying a house (already completed). However, there is a mobile phone mast with several antennas about 40 meters (130 feet) away from the house.
Buy or leave it? How would you decide?
Tassimat schrieb:
First, avoid using DECT, Wi-Fi, and smartphones yourself. If you can’t do that, there’s no point in worrying about the masts. Otherwise, it’s like preaching water and drinking wine.You can’t compare these devices to a fixed mast. On one hand, the exposure is temporary, and on the other hand, the signal strength decreases significantly with every meter. A mast transmits 24/7.nordanney schrieb:
... and is considered by experts almost in the realm of alternative facts So, which is it? Almost true or a myth? I just wanted to say that the topic is at least controversial. After all, there are established legal limits for electromagnetic pollution that are intended to protect against health damage. But yes, based on those defined limits, you could probably install a mast every 100m (330 feet).
nordanney schrieb:
Don’t get too worked up about that. Otherwise, you’d have to tell 80-90% of Germans that they are being exposed to radiation (in cities, it would be 100% of residents at 500m (1,640 feet)). Don’t worry, I’m not doing that. But it remains at least a controversially discussed topic.
nordanney schrieb:
If someone is really afraid of radiation, they logically avoid using mobile phones, Wi-Fi, high-voltage power lines, trains (because of high voltage). The devices and installations you mentioned cannot be compared to the transmitting behavior of a fixed mast.
nordanney16 Jan 2021 20:14WingVII schrieb:
The mentioned devices/systems cannot be compared to the transmission behavior of a fixed mast.No, that’s correct. The emitted radiation is actually higher!!!
