ᐅ Load-bearing capacity of an old house, wooden beam ceiling, single-family home
Created on: 9 Dec 2010 11:19
Tesla-1
9 Dec 2010 11:19
I want to place a home gym station on the first floor of an older building (wood beam ceiling/single-family house/year built: 1939), but I’m not entirely sure if the ceiling can support this weight.
  • Dimensions (LxHxW): 174x212x200 cm (69x84x79 inches)
  • Weight: 180 kg (397 lbs)
  • Maximum user weight: 100 kg (220 lbs)
  • Maximum load capacity: 130 kg (287 lbs)
I couldn’t find the load-bearing capacity of the ceiling in the old documents.
Should I consult a structural engineer?
MODERATOR
10 Dec 2010 14:19
Hello Tesla,
If you add up the loads, it would be a maximum of 310 kg (683 lbs) distributed over about 4 m² (43 sq ft) – so roughly 80 kg/m² (16.4 lb/sq ft).
This would be approximately equivalent to the following situation: Imagine standing with two or three friends, sharing a glass of wine – would you be worried whether the ceiling can support that?
Since I don't know the device or the ceiling, the condition of the wood, the dimensions of the joists, etc., it would still be advisable to have a structural engineer take a look at both the device and the ceiling; this should not cost more than 100 Swiss Francs.
Hannes1983-1
7 Apr 2015 10:50
We did the same and I was also unsure whether the wooden ceiling could support my fitness equipment. I couldn’t find any information in the documents either. So I hired a structural engineer for this. It cost me 80 CHF and he gave the green light.
No problem, the wooden ceiling can handle it.
herrmann-1
18 Apr 2015 12:06
But the data provided here shows that the ceiling can support this load. Of course, anyone who wants to be certain can also hire a structural engineer. However, they will not come to a different conclusion.
Hannes1983-1
5 May 2015 18:29
But if you hire a structural engineer, you are on the safe side. That reassured me as well, and it didn’t cost a fortune either.
U
Urs1988-1
29 Jun 2015 16:04
If you are unsure, you should bring in external expert advice for the house. But with this weight and load, nothing can go wrong. I’m not overly cautious. 😉
