ᐅ Carport with a wide span without an additional central support post
Created on: 7 Feb 2019 06:24
bortelGood morning,
I am currently looking into the topic of carports. Unfortunately, I haven’t found much information online; it seems that the usual carport manufacturers don't offer options for my needs.
What I require is a carport with a clear span of 7.2 meters (24 feet). Most common manufacturers only build up to 6 meters (20 feet).
I assume it will need to be a steel structure or a combination of wood and steel.
Do you know of any manufacturers that offer something like this? Visually, I would like to clad it with rhombus slats.
Caspar20207 Feb 2019 10:34As far as I know, they also do custom sizes over 12 x 7 m (39 x 23 ft). Just inquire directly.
try contacting
CP Carport GmbH
Waldschulstraße 28
63628 Bad Soden-Salmünster
That’s who made ours. They customize quite individually and, above all, use "self-supporting" roofs. This means that the parapet is simultaneously the load-bearing element. Because the parapet is much higher than the usual I-beams in a standard construction, you might have a chance there.
Andreas
try contacting
CP Carport GmbH
Waldschulstraße 28
Andreas
