ᐅ Maintaining Billy Shelving: Which Cleaning Products Are Suitable?
Created on: 11 Feb 2024 09:12
boteo
I recently got a Billy shelf unit from IKEA and want to keep it in good condition for as long as possible. I am particularly concerned about which cleaning products are best suited for maintaining this shelf. I understand that the shelf is usually made of simple particleboard with a melamine coating, but both aggressive cleaners and insufficient care can damage the surface.
Does anyone have experience or recommendations on which cleaning products work well to clean the Billy shelf thoroughly yet gently? Are there differences in cleaning stains with or without oil or dirt residues? And what are your thoughts on home remedies like vinegar water or rubbing alcohol?
Thanks for your input!
Wesley
12 Feb 2024 10:29
I agree with you, gentle cleaning is key! 🙂 I often just use lukewarm water with a little dish soap and a soft cloth. This usually works well to remove stains.
Sometimes, if I have something stubborn, I use a splash of glass cleaner. But nothing excessive, otherwise the Billy shelf starts to look worn out.
TRADI schrieb:
also, I would like to add that you should never use furniture polish on melamine surfaces
I totally agree with that 😉
Franck
13 Feb 2024 09:51
In short and simple terms:
- Use only mild soap or detergent solution
- Soft cloth
- Treat stubborn stains with diluted alcohol or glass cleaner
- No scouring agents, no furniture polish
That’s all you need. This way, the surface stays undamaged and looks nice.
tutan
14 Feb 2024 12:08
If anyone is still worried that mild cleaners might not be strong enough—don’t worry! If you clean gently and regularly, you won’t need a powerful cleaner, and your Billy will stay nice for longer.
I also find it quite pleasant to combine the cleaning process with a damp cloth and a bit of storytelling... maybe you sing your favorite song or dance a little 😉
boteo schrieb:
Which cleaning products are best suited for maintaining this shelf? Are there differences between stains without and with oil or dirt film?
For oil and grease stains, a little isopropanol (as fredle mentioned) or an alcohol-based glass cleaner works well for a short time. Other stains are usually water-soluble anyway.
Good luck and have fun keeping your Billy clean!
