ᐅ Is it possible to plaster over expanding foam insulation, and if so, how?
Created on: 2 Sep 2021 06:23
lesmue79
lesmue79
2 Sep 2021 06:23
Sorry for the possibly silly question, but is this possible? I often read online that it is, but there are no detailed explanations. For example, can you apply plaster directly onto the expanding foam (roughened surface, not smooth), or is it necessary to first apply a primer or some other bonding agent?
KingJulien2 Sep 2021 06:40
I can only tell you that we applied gypsum filler directly on it, and it was no problem.
BBaumeister
2 Sep 2021 08:33
That depends a bit on how large the area is where the expanding foam will be plastered. If it is just about filled cracks or similar, it can simply be plastered as is.
lesmue79
2 Sep 2021 08:50
The exterior area is the side reveal between the front door and the stair tread...
In terms of size, both the left and right sides are about 3 cm (1 inch) high, 20 cm (8 inches) long, and 1 cm (0.4 inches) deep.
The recess for the stair tread was a bit too large, so I first had to fill it with expanding foam.
BBaumeister
2 Sep 2021 09:04
I would additionally coat that with a waterproof slurry. Construction foam is not waterproof.
BBaumeister
2 Sep 2021 10:04
I might consider removing the expanding foam and using acrylic instead. The door frame will have a different expansion behavior compared to the masonry, and it is also subjected to vibrations from the door slamming shut.
