ᐅ Is it possible to have Kallax boards cut to size at a hardware store or home improvement center?
Created on: 5 Dec 2022 18:23
emirbar
emirbar
5 Dec 2022 18:23
I am currently planning my next DIY project with the IKEA Kallax shelving unit and have a question about whether the Kallax shelves can be cut to size at a hardware store. Specifically, I want to know if the material used for Kallax (usually glued wood with a melamine-coated surface) is typically accepted by standard cutting services at hardware stores.
Has anyone had experience with whether most hardware stores offer this service and if the quality or edges are affected by the cutting? Additionally, I am interested in whether the measurements are precise, since shelving often requires millimeter-accurate fitting.
I look forward to your insights and any tips, especially if anyone knows alternative ways to customize Kallax shelves without damaging the unit. Thanks in advance!
gasidney
5 Dec 2022 19:07
I gave it a try: hardware stores often cut chipboard panels, but with melamine-coated boards, the edges can sometimes chip or fray. For very precise measurements, it is usually worth consulting a professional or using edge banding to seal the edges.
sarlo
6 Dec 2022 08:45
gasidney schrieb:
Hardware stores often cut particle boards, but with melamine-coated panels, the edges can sometimes chip.
That’s exactly something you should keep in mind. The Kallax panels are melamine-coated, which means the cut edges often look rough and can be prone to chipping if they aren’t finished with a proper edge treatment. Hardware stores usually cut with stationary saws that provide straight cuts but don’t finish the edges.
If you have the panels cut at a hardware store, I recommend sealing the edges afterwards with suitable edge banding tape or iron-on edge tape. This can significantly improve both the durability and appearance.
emirbar schrieb:
whether the measurements are precise, since shelf inserts require millimeter-accurate fitting
Measurement accuracy at hardware stores is usually good, but slight deviations can occur due to manual handling. If exact fit is crucial, I suggest taking several measurements beforehand and possibly having the panels cut slightly larger at the hardware store, then fine-tuning them yourself with sandpaper or a file.
Alternatively, you can order from online cutting services specializing in furniture panels – they often offer even better quality in terms of cut and edge finishing.
nonpra
6 Dec 2022 12:36
Can confirm that hardware stores do cut such boards, but melamine edges often do not come out clean. I recommend ripping (cutting lengthwise) rather than cross-cutting, as it remains more stable. For precise fitting, there are online cutting services that are usually more accurate.
PeoDaniel
7 Dec 2022 09:18
emirbar schrieb:
whether the matching Kallax boards (that is, the shelves) can be cut to size at the hardware store
I had a similar project and can tell you from experience: yes, many hardware stores offer cutting services, but coated panels like those used in Kallax units are tricky. The melamine-coated surface can chip when cutting, and the edges often become rough.
Some hardware stores apply an edge banding foil for an additional fee. If not, you can also apply such a foil yourself with an iron. This significantly improves both the appearance and durability.
Also, make sure to double-check the measurements multiple times. I measured everything myself beforehand and confirmed it with a tape measure to avoid unpleasant surprises.
If you want a particularly fine finish, you can also inquire at furniture stores or specialized wood-cutting companies, as they typically provide cleaner cuts than hardware stores.
One more tip: if you get the Kallax boards cut, have the cuts made on a side that will be less visible later, in case the edge turns out a bit rough.
I hope this helps! 🙂
