ᐅ Is it possible to convert Ikea Pax into a bookshelf?
Created on: 20 Dec 2023 18:37
larsdu
larsdu
20 Dec 2023 18:37
I am considering converting my new Ikea Pax wardrobe system into a bookshelf to make it more flexible for my living situation. My question is: Is it actually possible to convert Ikea Pax into a bookshelf by adjusting the shelves and doors accordingly? I am especially interested in aspects such as the load capacity of the shelves, the stability during long-term use as a shelf, and whether there are any experiences with potential issues when storing thicker or heavier books.
Feedback, tips, and perhaps ideas on the best way to carry out the conversion are very welcome. Thank you in advance!
Palenar
20 Dec 2023 20:03
Hello Lars,
Regarding your question about whether Ikea Pax can be converted into a bookshelf, I would like to share some details and experiences. Basically, the Pax system from Ikea is clearly designed for use as a wardrobe, which means the shelves are usually made from relatively thin wood-based panels and are not specifically intended to permanently support heavy loads.
- Load capacity: The standard shelves generally hold around 15-25 kg (33-55 lbs), depending on the width and whether additional supports like center braces are used. Large and heavy book collections could quickly reach the load limit.
- Stability: You should make sure to secure the shelf parts very well with the connectors provided—especially if the shelf is tall. It is recommended to fully screw or fix the back panel, even if you leave out the doors, to prevent warping.
- Modification: You can theoretically remove the doors to make access easier. Replaceable shelves or stronger retrofitted boards can make the system more stable. However, if you have thicker or bulky books, it might be worthwhile to buy alternative shelving boards that rest on the Pax profiles.
Could you specify roughly how heavy your books are or how much space you plan to use? Then I can provide more detailed advice. So, I consider the conversion technically possible, but it requires some modifications and good stabilization.
Elijah42
20 Dec 2023 21:19
Yes, you can use Pax as a bookshelf, but the shelves are not designed for heavy loads. I would order stronger shelves and make sure to secure the system firmly to the wall.
dijan
21 Dec 2023 09:07
Hey Lars,
"Can you convert Ikea Pax into a bookshelf?" – cool idea! 😎 Sure, in theory, it’s possible since the modules are really versatile. But here’s a little reality check: some of the shelves are quite thin, so to prevent your collection of books from sliding or sagging, you should seriously consider reinforcing the shelves.
A tip from me: check out specialty timber suppliers for stronger boards that you can simply lay on top. Sometimes Ikea itself even offers sturdier alternatives. And if you don’t need the doors, remove them – it immediately looks more open and gives you more space to access your stuff.
If you add a bit of charm and a personal touch, you can turn it into a really nice DIY shelving gem! 😊 Good luck with it!
TRADI
21 Dec 2023 14:53
Palenar schrieb:
Could you specify how heavy your books are approximately or how much space you are planning for them? Then I can provide more detailed advice. Technically, the conversion seems possible, but it requires some modifications and proper reinforcement.
Hello Lars,
I would like to add that it is very important to accurately assess the load. Books can become very heavy quickly, especially if you have hardcover editions or elaborate art books. Standard Ikea Pax shelves are not designed for that; there is definitely a risk they will sag or eventually break.
If you intend to use the shelving daily, I recommend adding an additional central support beam to the shelves or installing strong solid wood boards instead.
Anchoring the entire cabinet securely to the wall is also a critical safety factor. This will keep the unit stable and secure.
If you want, I can provide more tips on materials and installation.
