ᐅ Can the KALLAX unit be securely installed as a partition wall?
Created on: 6 Oct 2024 08:27
ROBINFLO
I am currently planning to use an IKEA KALLAX shelf unit as a room divider in my apartment to visually and spatially separate an area. However, I am wondering if the KALLAX can be securely fixed as a partition so that it stands stable and can withstand long-term loads.
Specifically, I am interested in whether the shelf must be attached to the wall with fasteners, or if there are ways to set it up freestanding while preventing it from tipping over. What experiences do you have with using KALLAX as a room divider?
I would appreciate tips on safe installation and advice on which measures are necessary to effectively prevent tipping or sliding.
Thanks in advance!
koduga
7 Oct 2024 07:56
I consider safety with room dividers like KALLAX to be very important, especially when children or pets are around. I am always concerned that a piece of furniture might topple over if bumped.
Therefore, before making a decision, I would carefully check how stable the fixation actually is. From my experience, it’s not enough to simply place the shelf loosely. Even if you think it can be secured freestanding, there is still a high risk of it tipping over.
What experiences have you had with load capacity? Have the brackets loosened for you, or does the wall sometimes pull out when the load is too heavy? This is definitely an issue to consider, especially in rental apartments.
likuken
7 Oct 2024 09:42
Let's be honest: If you think you can safely use the KALLAX as a room divider without securing it, you’re probably relying too much on luck.
RENMA schrieb:
The small-sized plug-in modules are not strong enough to stand stable by their own weight or any loads
Many people underestimate this. Furniture is not the same as solid walls. IKEA did not design the KALLAX as a load-bearing wall. If you choose to ignore this, I have full respect for you—it’s like freedom fighting physics.
In short: Screw it firmly in place or don’t do it at all. If you think that’s being overly cautious, you don’t understand structural stability.
Domau0
7 Oct 2024 11:13
For safety when using the KALLAX shelving unit as a room divider, I would like to add some technical details.
The KALLAX is made of particleboard with a thin melamine coating – this makes it relatively lightweight but also susceptible to mechanical stresses outside its intended use.
The stability largely depends on the floor surface and how it is fixed. For secure fastening, I recommend:
- Using at least two mounting brackets at the top of the unit, anchored to the wall (with appropriate wall plugs depending on wall type).
- If possible, add additional fastening at the bottom, for example with floor brackets or rubber anti-slip mats.
- When used freestanding, keep in mind that even slight lateral forces can cause the unit to tip over.
Furthermore, I strongly advise not to rely solely on wooden or concrete walls for mounting. If dealing with drywall or lightweight partition walls, check whether the fixings will hold properly – special cavity anchors or other solutions may be required.
koduga schrieb:
Wurden bei euch die Winkel auch gerne mal locker oder reißt die Wand raus
This is a valid concern; please choose the anchors accordingly!
ROBINFLO schrieb:
Welche Erfahrungen habt ihr mit der Nutzung von KALLAX als Raumteiler gemacht
One additional tip: to further increase stability, you can attach a thin plywood panel to the back of the KALLAX, which will provide extra reinforcement.
What are the specifics of your room? Wall material, load requirements, etc.?
