ᐅ Can Pax units be used as room dividers?
Created on: 30 Sep 2024 09:23
Sufa47
Sufa47
30 Sep 2024 09:23
I am considering using my IKEA Pax wardrobe as a room divider to create a visual separation in my open living and sleeping area. I am particularly interested in how practical and stable the Pax really is for this purpose.
Can a Pax wardrobe truly be used as a room divider without tipping over or being too bulky and inflexible? What about the back side – is it visually appealing, or would additional paneling be necessary?
I would also like to know how easy or complicated it is to assemble and modify the wardrobe, in case I want to move it somewhere else later.
Does anyone have experience or tips on using the Pax as a room divider?
Thank you in advance!
Jensson
30 Sep 2024 10:37
Hello Sufa47,
First of all: Yes, the IKEA Pax can definitely be used as a room divider – but there are some important considerations.
1. Stability:
Pax is mainly designed as a wardrobe for wall mounting. Without wall anchoring, it can tip over, especially when standing freely as a room divider. However, there are special anchoring options, such as ceiling anchors or floor fasteners, which can be installed separately.
2. Back panel:
The back is usually quite plain, often just a thin backing board. This can be visually challenging if it is visible. Some users add a decorative wooden panel or line the back with fabric or wallpaper to make it look more appealing.
3. Flexibility:
Assembling and disassembling Pax is generally possible but not always straightforward – especially if there are many cabinet elements, frames, and doors involved. It’s advisable not to choose a cabinet that is too large to reduce effort in transportation and reassembly.
4. Tips:
- Use modular Pax components that you can adjust as needed.
- Make sure to anchor it properly to avoid safety risks.
- Plan the appearance of the back panel as well.
In summary: Using Pax as a room divider works, but requires some adjustments and careful planning. Many people have had positive experiences – stability is key!
If you want, I can also prepare a small checklist to help you get ready.
dijan
30 Sep 2024 11:52
Jensson schrieb:
Pax is mainly designed as a wardrobe for wall mounting. Without being fixed to the wall, it can tip over, especially when used as a room divider standing freely.
Jensson is absolutely right; that’s the key point.
Personally, I think using the Pax as a room divider gives a really cozy feel—kind of like "living room meets bedroom." But yes, a bit of extra DIY effort doesn’t hurt to make sure it stands securely.
A small tip: Adding a back panel with interesting patterns or even upholstering it with fabric can visually soften the whole thing and make it feel more homely. This way, the wardrobe doesn’t look like a bulky block right in the middle of the room.
And don’t worry—the assembly and disassembly aren’t super easy, but they’re definitely manageable. With two people and a bit of patience, it works out fine.
If you find it too solid or heavy-looking, maybe try combining it with some open shelving elements—that lightens the overall appearance and lets more light through.
ju_ren
30 Sep 2024 12:14
Using Pax as a room divider is possible but it must be securely fastened. The back side is not attractive, so it is better to cover it. Assembly and disassembly are moderate in difficulty; plan your time accordingly.
GALEO4
1 Oct 2024 07:45
Sufa47 schrieb:
Can a Pax wardrobe really be used as a room divider without tipping over or being too bulky and inflexible?
To be honest: I think anyone using the Pax as a room divider hasn’t quite understood the purpose of the furniture. It’s designed for wall units that sit flush against a wall. As a room divider, it looks like someone just plunked a massive block in the middle of the room. Calling it bulky is an understatement.
If you’re really looking for a room divider with minimal effort, there are more elegant pieces of furniture or partition screens that don’t rely on the “take the biggest wardrobe and turn it sideways” approach. But yes, stability and the appearance of the backside are the main issues—nothing new, Jensson already summarized that well.
My advice: better to choose something specifically made for that purpose rather than DIY solutions that hardly satisfy visually or functionally.
