ᐅ Is it easy to make minor repairs or modifications to Malm furniture yourself?
Created on: 14 Aug 2019 20:23
donar
donar
14 Aug 2019 20:23
Hello everyone, I am considering refinishing some of my Malm furniture myself to remove minor scratches and refresh their appearance. I am particularly interested in how easy or difficult this is for someone with basic DIY skills. Do you need special tools or materials, or are simple household remedies enough? Which steps are really essential, and what should you definitely watch out for to avoid damaging the original material? I look forward to hearing first-hand experiences and tips, ideally including advice on how you dealt with common issues like faded surfaces or chipping.
pakokla
14 Aug 2019 21:05
You can easily touch up minor scratches using furniture wax or special repair markers. Simply apply and polish with a soft cloth. For more significant damage, sanding and repainting are necessary, which requires more effort.
fugolo
15 Aug 2019 08:41
To answer your question thoroughly: Malm furniture is usually made of laminated particleboard, which limits refinishing options somewhat. Start by cleaning the surface to remove dirt and oils. For scratches, special repair wax sticks available in wood tones work well. Important: apply these products sparingly and in thin layers. For faded or chipped areas, you can try gently sanding the surface and resealing it with a suitable paint or clear coat. Be careful to use a coating that is compatible with the original laminate to avoid unsightly edges. Tip: always test on an inconspicuous spot before working on larger areas. For deeper damage, replacing individual parts is often more practical.
sarla
15 Aug 2019 12:17
Malm furniture is usually coated with melamine resin or foil finishes, which make refinishing challenging. The foil is thin and sensitive to mechanical stress and solvents. For minor scratches, special furniture care products or repair waxes are recommended. For more significant damage, sanding can harm the surface. It is important not to use coarse sandpaper and to apply a protective layer after treatment. Tools: fine sandpaper (e.g., grit 320 or higher), furniture wax, color pencils, and water-based clear coat. If unsure about the process, it is better to consult a professional, as the foil cannot be easily replaced.
Genevieve
15 Aug 2019 19:52
fugolo schrieb:
Malm furniture is usually made from laminated particleboard, which limits post-processing somewhat.
Exactly – that’s the crucial point. I often see people talking about sanding and painting without considering how thin the laminate on Malm furniture really is. This means that if you work too aggressively on the surface, you risk sanding through the laminate completely and exposing the substrate, which quickly ruins the appearance.
sarla schrieb:
Tools: fine sandpaper, furniture wax, touch-up markers, and water-based clear varnish.
However, I would be cautious with clear varnish; if it’s not an exact match, it can easily change the gloss level or create visible edges. My recommendation: better to work with repair kits locally and avoid large-area refinishing. Does anyone here have experience with special laminate or decor repair kits that actually work well?
pakokla
16 Aug 2019 07:33
I have had good experiences with repair wax, which adapts well to the color. I would only sand in case of very severe damage and then only very carefully. When the film is damaged, any repair is always a compromise.
