ᐅ Can Kallax corners break with frequent moving?
Created on: 11 Oct 2023 09:17
tanner_lau
I am currently considering getting a Kallax shelving unit because I really like the flexibility and modular design. However, my main concern is whether the typical corners of the Kallax modules are prone to breaking or cracking with frequent transportation, such as moving or changing the location often.
I understand that the shelves are designed to be stable, but has anyone experienced that damage tends to occur more often at the joints or corners? Or are these areas durable enough to withstand repeated transport? This is important for me to know, as I might want to rearrange or take the shelving unit with me regularly. Thanks for your insights!
Laukau5
11 Oct 2023 18:46
I would like to go into more detail about the materials and construction method of Kallax to provide a more informed answer.
Kallax is essentially a particle board construction with a melamine resin coating. The corners are glued and often additionally joined with dowels or fastened in other ways. This holds up very well under static use. However, frequent transportation can cause mechanical stress that may lead to the glue joints coming loose and cracks forming.
How the transport is carried out is important: if the modules are moved fully loaded, the forces distribute differently than when transported empty. Carrying the unit at the wrong points generates high shear forces at the corners.
In our experience, the risk is especially high if the furniture is not individually packaged or simply dragged over edges.
My question for you: How often do you approximately plan to transport the unit, and how heavy will it be when loaded? This information helps to assess the level of stress it will experience.
tanner_lau
11 Oct 2023 19:12
Laukau5 schrieb:
My question to you: How often do you roughly plan to transport it, and how heavy will the loaded shelf be?
Thank you for the detailed explanation. The shelf will probably be transported about once every 2 months (every 2 months), usually empty or only with very light contents. So the weight will remain relatively low, but the shelf will be subjected to small vibrations or movements in the vehicle at times. I hope this will help minimize the risk of cracks.
blapau
12 Oct 2023 07:43
With a transport interval of about two months, especially with light loading, I consider the risk of the Kallax corners breaking to be low. However, when loading, attention should be paid to even weight distribution to avoid unnecessary pressure points.
Additionally, I would recommend protecting the corners during transport with padding, such as foam or blankets. Small vibrations are usually not problematic, but direct impact stresses should be avoided.
tanner_lau
12 Oct 2023 09:09
blapau schrieb:
I recommend protecting corners during transport with padding, such as foam or blankets.
That's a great tip, thanks! I've often wondered whether some kind of protective cover or at least blankets around the shelving unit would be useful. I'll definitely keep that in mind.
tra_nina
13 Oct 2023 08:31
As an additional note: Kallax is not designed for frequent mobile use, but rather for stationary placement. If frequent transportation is unavoidable, I recommend disassembling the shelf into its individual parts before moving it.
This helps avoid mechanical stress on the corners and joints. Although reassembly can be a bit time-consuming, it significantly reduces the risk of damage to the shelf. Additionally, the individual parts can be better cushioned during transport.
