ᐅ Is it possible to convert Ikea PLATSA units to use external fittings?
Created on: 5 Feb 2021 14:23
LijohannHello everyone,
I am currently looking into the Ikea Platsa system and wondering if it is generally possible to retrofit this modular wardrobe system with external hardware. Specifically, I am interested in whether the original hinges, drawer slides, or handles can be replaced with alternatives, for example, if you prefer special accessories or higher-quality fittings. Are there any structural limitations with the Platsa series that would make retrofitting with external hardware difficult or impossible? I would appreciate any experiences, tips, or information on compatibility. Thank you in advance!
Basically, Ikea PLATSA can be retrofitted with external fittings, but you need to ensure that the new parts are compatible or can at least be adapted to the existing drill holes. Simply replacing handles or hinges is usually possible without major issues. Drawer slides can be more challenging because they are often designed specifically for the construction.
For clarification: Ikea’s PLATSA system uses standardized drilling patterns, with the holes pre-drilled during the manufacturing of the modules. This generally makes it easier to replace the fittings, but it does not necessarily mean that all external brands will fit without issues. For example, hinges often follow a standard hole spacing (e.g., 35mm (1.4 inches) for many European models), which increases compatibility.
However, caution is advised with drawer slides, as Ikea often uses special models mechanically matched to the front and internal dimensions. A simple modification moving them outward or inward could affect the drawer’s operation. It is therefore recommended to carefully check the measurements even when using external fittings or to adjust the slides separately.
In summary: fittings can be retrofitted if you pay close attention to the dimensions and mounting points and make any necessary adjustments to the drilling.
Hey, great question! 😎 I think the best thing about PLATSA is definitely its modular design. If you swap the fittings for higher-quality or more stylish ones, you give the whole thing a unique touch. Of course, you need to pay attention to how the holes line up, otherwise it can quickly turn into an advanced DIY project. 😅 But with a little patience, it’s definitely doable.
That’s definitely true! I’d recommend starting with less critical parts like handles or hinges. For the slides, it’s probably better to stick with the originals to avoid complications.
Have fun with your building!
barsar schrieb:
Drawer slides can be more challenging since they are often tailored to the specific construction.
To complete the technical perspective: The PLATSA modules are based on a frame construction with predefined drilling points that simplify the attachment of the original fittings. This standardization allows for a certain degree of interchangeability, but the key factor is the compatibility of the new fittings.
Important points:
- Drill hole distances must match or be modified
- Material thicknesses and load capacity of the fittings must be suitable for the PLATSA system
- Especially for drawer slides: check the running mechanism, as different models can negatively affect smooth operation and durability
Therefore, before any modification, it is essential to compare technical data or even verify the measurements yourself to avoid mistakes.
Important points:
Cecilera667 Feb 2021 21:07Lijohann schrieb:
whether the original hinges, drawer slides, or handles can be replaced with alternatives, for example because you prefer specific accessories or higher-quality hardware. This usually works well with handles and hinges. Drawer slides are more critical due to internal dimensions and running mechanisms. I would only use hardware that fits the measurements or can be adapted with minimal effort.
