ᐅ Is it easy to disassemble and reassemble IKEA Hemnes furniture?
Created on: 4 May 2022 09:23
narsabriHello everyone,
I have a specific question about IKEA Hemnes furniture: To what extent can these pieces—such as cabinets, beds, or dressers—be disassembled and reassembled without compromising their stability or fit?
I plan to use some of this furniture multiple times, possibly during a move, so I’m especially interested in how many times the components can be taken apart and put back together without damaging the material or degrading the quality of the screws and joints. Are there common weak points where problems tend to occur quickly? What are your experiences with retightening screws, and do you end up needing more tools than expected? Are there any special tips to handle this with minimal damage?
Thanks in advance for your detailed insights!
FeAndreas14 May 2022 11:47Hello narsabri,
I completely understand your question, as Hemnes is really common and many people face exactly this issue. From my experience, Hemnes is quite solidly built, but there are some important details to consider when disassembling and reassembling it.
First of all: The wood is usually solid pine, which is generally sturdy, but it is sensitive to repeated screwing and unscrewing—especially if the screws are driven directly into the wood rather than into dowels or threaded inserts. Hemnes uses a mix of both.
Typical weak points are:
- The connection points where screws go directly into the wood surface can widen over time and then lose holding strength.
- The connecting hardware (such as cam locks or hinges) is sturdy, but you should avoid adjusting them too often, or the threaded holes may wear out.
Regarding tools: A well-fitting Allen key is essential. Some models also use Phillips screws. I recommend gently tightening all screws before disassembling, avoiding excessive force to prevent crushing the wood.
My tips:
- Loosen screws gently at first to avoid damaging the material.
- If you plan to disassemble the furniture frequently, consider installing small furniture connectors in critical spots that are designed for repeated assembly and disassembly.
- Carefully document which screws go where in each part beforehand—this makes reassembly much easier.
Are you planning to move the furniture often, or is this a one-time process? In my opinion, this affects how much wear you might actually see.
My tips:
- The connection points where screws go directly into the wood surface can widen over time and lose their grip.That’s a good starting point. However, I wonder – is this really a general problem, or does it depend more on how the furniture is handled? If the screws are tightened with the usual torque and the furniture is not constantly taken apart and reassembled, I can’t imagine the joints failing so quickly.
Hemnes, in particular, is designed as solid wood furniture, which should provide a certain level of stability. You mention “not repeated readjustments,” but how often are these actually practical in everyday use?
Another important aspect is the storage of the furniture parts between assemblies. Moisture and temperature fluctuations can cause the wood to swell, which affects the fit.
My hypothesis: Hemnes furniture can definitely be disassembled and reassembled multiple times if some basic rules are followed:
- Carefully and evenly loosening the screws
- Avoiding overtightening or stripping the fasteners
- Using appropriate tools and replacing worn parts if necessary
However, I would disagree with the statement that the furniture is fundamentally not made for multiple disassemblies.
I would be interested to hear if anyone has concrete experience with frequently moving the furniture – perhaps more than twice. How has the material held up in the long term? Are there any negative effects, such as cracks or chips in the wood?
Matthewt486 May 2022 15:04narsabri schrieb:
Are there typical weak points where problems tend to occur quickly? What are your experiences with tightening the screws again, and do you end up needing more tools than expected?Hi narsabri,
I have successfully assembled and disassembled Hemnes furniture several times, including multiple cabinets and dressers, even during moves. My experience:
- Weak points are usually the connection holes in the wood and where the screws are placed – if loosened too often, these can become worn out or slightly damaged.
- Retightening the screws during reassembly is important, especially since the wood can shift a bit during transport or storage.
- In terms of tools, you generally only need an Allen key (hex key) and a screwdriver; occasionally a cordless drill can help make the work easier.
It’s important not to overtighten the screws during assembly and to handle everything carefully to keep the threads intact. If holes do get enlarged, using small wooden dowels for repairs can be useful.
What is often underestimated is the assembly sequence, which is crucial for stability. So make sure to follow the instruction manual closely and stick to the recommended order to avoid tension or misalignment.
I can definitely confirm that careful handling allows for multiple disassemblies and reassemblies without problems.
