ᐅ Is it possible to combine IKEA Hemnes furniture with other pieces, and how does that work?
Created on: 8 May 2017 10:14
son33
son33
8 May 2017 10:14
I am currently exploring to what extent IKEA Hemnes furniture pieces can be easily combined with other furniture lines or individual items without creating a visually cluttered or stylistically inconsistent effect. Specifically, I am interested in which factors play a role when mixing these pieces—such as color and material coordination, proportions, or perhaps design details. I would also like to know if anyone has practical tips on how to integrate Hemnes into various interior design concepts, especially if you already own certain Hemnes elements but want to add new furniture that is not from the same collection. Does anyone have experience with such combinations and can explain how this works in practice?
barEsperan
8 May 2017 11:37
Basically, Hemnes furniture can be easily combined with other pieces as long as the colors and materials match. Pay attention to wood tones and shapes to create a harmonious look. Avoid mixing too many different styles in the same room.
RETRAVIS
8 May 2017 12:05
To successfully combine Hemnes with other furniture, consider the following points: - Color coordination: Hemnes is often available in white or various wood tones, so it is advisable to choose either similar shades for other furniture or work with complementary contrasting colors. - Material harmony: Hemnes is mainly made of solid pine with paint or stain. Furniture made of solid wood or with similar finishes fits well. - Stylistic integration: Hemnes has a classic and slightly rustic style. Modern, minimalist furniture can be combined if they have clean lines and create color harmony. Important: maintain a consistent design theme in the room. - Proportions: size ratios and heights should be balanced to avoid a disrupted overall appearance. Successfully integrating Hemnes with other furniture relies on deliberate design choices, always paying attention to color and material coordination.
Ramon4
8 May 2017 16:23
I have combined Hemnes furniture with other pieces myself and found that it works well if you keep a few things in mind. The most important factor is that the wood tones of the furniture match reasonably well – for example, if your Hemnes piece is white, the additional furniture should also be in lighter shades. Another tip is to stick to a consistent style concept, such as a country or Scandinavian modern look. Personally, I have had good experiences complementing Hemnes with simple, color-coordinated furniture from other brands that isn’t too ornate. This way, the overall look doesn’t become too cluttered. Accessories and textiles also help to tie everything together. Are there specific pieces you are considering, or do you want to plan the mix more generally at this stage?
son33
8 May 2017 18:47
RETRAVIS schrieb:
Important: Maintain a consistent design theme in the room.
This seems to me to be a key point. But if I want to integrate individual Hemnes cabinets or dressers into an otherwise rather modern living space, can that work? I find this style quite distinctive and would assume that you would need to work with clear shapes for the additional furniture, or are there other possibilities?
Ramon4 schrieb:
Another tip: Try to stick to a consistent style concept, for example, either country house style or Scandinavian modern.
I’m considering whether it might also work to deliberately break Hemnes style, that is, to create a deliberate contrast to generate an interesting interplay. Does anyone have practical experience with this? How could something like this be done well without it looking like mismatched furniture simply put together?
Laukau5
9 May 2017 09:12
To address the question of how IKEA Hemnes furniture can be combined with other styles, especially in modern interiors: Hemnes is characterized by classic, clean lines with a touch of country charm, made from solid pine wood. The surface is usually lacquered, which simplifies the color choice.
A successful mix with more modern furniture often works through the following approach:
- Use color contrast as a design element: Complementary furniture in matte black, gray, or even metallic finishes can nicely break up Hemnes pieces when the shapes are clear and cubic.
- Recurring elements create harmony: For example, with side tables, shelves, or lamps, you can make sure certain materials like metal or glass are deliberately used as accents.
- Uniform proportions: Very delicate or extremely bulky furniture may visually compete too much. Measure your Hemnes furniture carefully and look for additions that are comparable in height and volume.
- Accessories and textiles: Rugs, cushions, and curtains can help bring different styles together and balance compromises.
A side question: How extensive is your current Hemnes collection, and which pieces are you considering adding? I ask to better estimate how dominant Hemnes would be in the room.
