ᐅ Is it possible to use IKEA BRIMNES for DIY upcycling projects?
Created on: 28 May 2018 10:07
Henningla
Henningla
28 May 2018 10:07
I am currently planning a DIY upcycling project and wondering if the IKEA Brimnes furniture series is suitable for this. Specifically, I am interested in how stable the materials are, whether the assembly can be modified, and how well the surface can be sanded or painted without compromising the furniture’s functionality. Does anyone have experience with BRIMNES in the DIY field, especially in the context of upcycling? I am also curious whether the construction is more lightweight or sturdy, and if the furniture parts can be easily disassembled to create new designs. I would appreciate any tips, warnings, or examples!
maureo
28 May 2018 11:32
Henningla schrieb:
Specifically, I’m interested in how durable the materials are, whether the construction can be modified, and how well the surface can be sanded or painted, for example.
The materials are MDF with a film coating, sturdy enough for normal use. Sanding is possible, but you need to be careful since MDF swells quickly when exposed to moisture. Painting works well, preferably after applying a primer. The construction is modifiable, but not as durable as solid wood.
maflo
28 May 2018 14:19
I have already completed several small projects using furniture from the BRIMNES series; here are a few tips:
- The panels are MDF with a foil surface, which makes sanding difficult. It’s best to first remove the foil carefully with a sharp scraper.
- Then, roughen the surface with 120-grit sandpaper and apply a good primer (e.g., acrylic primer) before painting.
- You can carefully fill screw holes and joints with wood filler if you want to close any gaps.
- The construction is fairly simple, can be disassembled, but cannot be extensively modified without losing stability.
Also, be careful not to drill through or heavily alter the load-bearing parts, as this will affect stability. Overall, BRIMNES is well suited for decorative upcycling projects; for more substantial functional changes, I would recommend sturdier furniture.
reoWilhelm
29 May 2018 09:21
Henningla schrieb:
I’m also interested in whether the construction is more lightweight or sturdy, and if the furniture pieces can be easily taken apart
I can confirm that the BRIMNES parts are designed more for lightness and cost-effective production. Still, it feels stable enough as long as you don’t expect solid wood level durability. Taking them apart works quite well—I once completely disassembled a dresser to repaint it and add small modifications. Definitely not a problem if you have some basic DIY skills.
One more tip: take your time during disassembly, the screws and dowels are typical IKEA style, so you can make some adjustments. However, you should prepare the surfaces very thoroughly, or the new paint won’t adhere properly.
Have fun with your upcycling project!
cassandra
29 May 2018 12:38
In summary:
- The BRIMNES series is made of MDF panels with a foil coating, which limits its suitability for DIY upcycling.
- Sanding is possible but should be done carefully due to the foil and MDF’s sensitivity to moisture.
- A primer is required beforehand to ensure proper paint adhesion.
- The furniture is easily disassembled thanks to its modular design but is less suitable for structural modifications.
- BRIMNES is suitable for decorative changes but less appropriate for extensive functional alterations.
These points are important to avoid damage and loss of stability. Anyone planning significant renovations should carefully consider these factors in advance or opt for other types of furniture.
