ᐅ Is it possible to use Ikea Brimnes furniture for DIY restoration projects?
Created on: 9 Dec 2021 20:37
TurolaHello everyone, I am planning to use the Ikea Brimnes system for restoring older furniture pieces in a DIY style, but I am unsure if it is really suitable. Specifically, I am wondering if the furniture parts from the Brimnes wardrobe can be taken apart and modified or rebuilt in a way that allows them to serve as a base for custom furniture projects, such as shelves or storage solutions with a fresh look. Does anyone have experience with how sturdy the Brimnes modules are for such purposes and whether the wood or MDF material is easy to work with? Maybe there are also tips on surface treatments or how to typically handle the fittings when assembling the furniture in different ways. Thanks for your opinions!
Hey Turola, great question! 😄 I’ve worked with a few Ikea parts myself, including Brimnes, and I can say the system is not as inflexible as you might think. Of course, the panels are MDF with a melamine coating—not exactly ideal for visible woodworking, but definitely suitable for DIY upcycling.
You definitely can! The connections are usually made with dowels and cam lock screws, which can be undone fairly easily without damaging everything—if you’re careful. Sometimes the edges are quite delicate, and the MDF panels can swell in certain spots if you sand or drill too much.
For surfaces, I’d recommend paint or adhesive film rather than heavy sanding, because the surface on Brimnes isn’t very durable against abrasion. But don’t worry too much: for cool shelves, small boxes, and modifications, the material works great—especially if you give it a fresh coat of paint or apply some film.
Overall, I’d say Brimnes is a fairly affordable playground for creative ideas, but it’s no substitute for solid wood when it comes to classic furniture restoration. Good luck and have fun with your projects! 🍀
Turola schrieb:
whether you can take apart the furniture pieces from the Brimnes wardrobe and modify or rebuild them to serve as a base for your own furniture projects
Hello Turola, I would like to address your question in more detail since I have worked with Ikea furniture several times – including Brimnes.
The biggest advantage of Brimnes is that the individual parts are modular and can often be taken apart relatively easily. This makes it quite attractive for DIY projects, especially if you don’t want to completely destroy the parts. However, as raulso already mentioned, MDF is somewhat delicate, especially at the edges. When working on it, you should keep the following points in mind:
- Avoid heavy sanding on the edges, as the melamine coating can chip off quickly.
- Use drill bits with a sharp tip and work with low torque if you want to add extra holes.
- During assembly: The Minifix screws are solid but not designed to be taken completely apart and reassembled multiple times. It’s advisable to have spare parts ready in case the holes become worn out.
- For surface treatment, spray paints or films are recommended because they adhere well to the smooth melamine surface.
If you want to make truly important load-bearing parts, Brimnes is not the best choice, as the material thickness and quality cannot compete with solid wood or plywood panels. However, the system is well suited for shelves, storage, or decorative elements.
If you need more information about surface treatment or tool tips, I’m happy to help!
jordanvin10 Dec 2021 19:29sarlo schrieb:
The biggest advantage of Brimnes is that the components are modular and they can often be taken apart quite easily.I also think that is really important! About two years ago, I experimented a bit with Brimnes and made an open shoe cabinet that fits my hallway really well. What I especially liked was that you can achieve great results with simple means and minimal professional tools.
raulso schrieb:
For surfaces, I would rather recommend lacquer or foilExactly! With a bit of patience and spray lacquer, the result looks much more refined. I would also suggest using edge banding on the open edges to avoid a cheap look and to protect the MDF boards.
Regarding durability: I found the Brimnes modules sturdy enough to easily withstand everyday use, as long as you don’t treat the edges too roughly. For larger furniture projects, the parts can be combined or joined nicely. For my purposes, it was worth it if you want to stay flexible and don’t have a huge budget!
So, don’t hesitate – Brimnes is easy to refurbish and creatively modify! 😃
