ᐅ Can I use IKEA Metod kitchen cabinets in rooms with high moisture levels?
Created on: 18 May 2021 14:37
Sion2Hello everyone,
I am currently planning the renovation of my bathroom, including a new kitchen corner within it. Due to limited space, I am considering using IKEA Metod kitchen units. This raises the question: Is it safe to use IKEA Metod kitchen units in damp areas such as bathrooms or open kitchens with high humidity, or are there specific restrictions for their use in such moist environments?
I am particularly interested in how resistant the materials are to moisture and whether any issues like swelling, warping, or material deformation can be expected from their use.
Does anyone have experience or reliable information on this? Thanks in advance!
IKEA Metod kitchen units are not designed for wet rooms by default.
- Direct contact with water and high humidity can damage the material.
- With careful sealing and good ventilation, it usually works, but there is still a risk.
I would recommend them more for standard kitchens, not for bathrooms.
For additional information:
- The IKEA Metod furniture system primarily uses medium-density fiberboard (MDF) with melamine-coated surfaces.
- These materials are not waterproof and will swell and deform if exposed to moisture for extended periods.
- The manufacturer does not provide any guarantee or recommendation for use in wet areas such as bathrooms.
If Metod furniture is to be used in wet rooms despite this, special protective measures are essential, such as waterproof seals, edge sealing, installing the furniture without direct floor contact, and ensuring good room ventilation.
flo-Theres19 May 2021 09:12hauklo schrieb:
The manufacturer does not provide any warranty or recommendation for use in damp rooms such as bathrooms.This is the key point for me. There are definitely more suitable furniture series for damp areas. If IKEA Metod is the only option, please especially consider the following points:
- Carefully seal doors and edges with water-repellent paint or silicone
- Install floor protectors or plinths in a way that prevents moisture from entering from below
- Regularly ventilate to avoid moisture permanently settling on the furniture
Without these measures, I do not recommend Metod for damp rooms, as damage is inevitable.
V
vincent4620 May 2021 21:46I fully understand how important it is to have a clear understanding of the materials when choosing furniture for wet rooms.
I completely agree. I once had Metod furniture in the bathroom, and despite all precautions, the underside of the cabinets started to swell after about a year. It was frustrating because I had taken good care of them with proper ventilation and protection.
My recommendation would be to opt for specially moisture-resistant furniture from the start, especially if the room is not well ventilated, to avoid long-term disappointments.
Still, I can understand why many choose IKEA because it is affordable – but the moisture issue really should not be underestimated.
