ᐅ Is it possible to replace the back panel on IKEA PLATSA shelving units?
Created on: 24 Sep 2022 19:27
Jan57
Jan57
24 Sep 2022 19:27
Hello everyone, I am planning to customize an IKEA Platsa shelving unit and am wondering if it is possible to replace the back panel on these shelves.
My question is: Can the standard back panel on Platsa units be swapped out for a different one? I am particularly interested in whether the back panels are easy to remove, how they are fixed in place, and if there are any good alternatives available in case I want to use a more stable or visually appealing back panel.
I would appreciate any experiences, tips, or suggestions on compatible back panel materials. Thanks in advance!
flo-Theres
24 Sep 2022 21:03
Jan57 schrieb:
My question is: Is it possible to replace the standard back panel on the PLATSA shelves with a different back panel?
Yes, basically you can change the back panel, as it is usually just slotted or clipped in place. Ikea typically uses thin hardboard panels for PLATSA, which are relatively easy to remove and replace.
However, you should keep in mind that the back panel is important for the shelf’s stability. If you want to use an alternative back panel, I recommend:
- Choosing a material with similar thickness and strength
- Measuring and adjusting the fastening options (slots, clips) accordingly
A back panel made of MDF, thin plywood, or other hardboard sheets usually works well. Also, consider adding double-sided tape or small brackets if the original fastening doesn’t fit.
The shelf should remain stable with a different back panel as long as it is properly secured.
If anyone has used other materials, I would appreciate hearing about your experiences.
JORDON
25 Sep 2022 08:43
flo-Theres schrieb:
Ikea usually uses thin hardboard panels for PLATSA, which can be removed and replaced quite easily.
I like when you can basically “upgrade” a shelf without having to buy a whole new one! 😄
I added a back panel made of painted plywood to my PLATSA, which looked much warmer visually.
Attaching it was pretty quick—just small screws and brackets—and it holds very well. The stability even seemed better than before, at least to me.
So if anyone is feeling a bit DIY, try swapping the back panel; it really brings a fresh look to the IKEA shelf.
bupar
25 Sep 2022 11:59
Jan57 schrieb:
Is it possible to replace the standard back panel of the PLATSA shelving units with a different one?
The back panel of the PLATSA series is designed as a structural element that provides fundamental load-bearing support for the shelving unit. It is usually inserted or slotted in, making it generally replaceable.
When replacing the back panel, the following points should be considered:
- Material thickness and type: The original back panels are made from thin but tightly glued hardboard, approximately 3 mm (0.12 inches) thick.
- Method of attachment: The back panel is often secured by slots in the side panels. A new back panel must be cut precisely to size and fixed securely using appropriate clips or corner brackets.
- Impact on stability: Any deviation from the original design could negatively affect stability, especially if alternative materials are used without adequate back panel reinforcement.
In summary, replacement is possible but requires precise work, selection of materials with similar properties, and secure fastening to avoid functional or safety issues.
